18/19in rim size recommendation plz!
Old Mar 27, 2003 | 03:39 PM
dclub01's Avatar
Default 18/19in rim size recommendation plz!
I was planning to put some 19in on the rear and 18in in the front of a 92-95 civic coupe. I was wondering if anyone could tell me the right size or max size to fit properly on this car as far as width, offset, etc. I also plan to lower the car as well, but maybe only like 2-3in in the front and 1.5-2.5in in the back...
Is it possible to put 19s on a civic? Thx ahead of time!
On another note, can some plz explain to me why the wheel cavity curvature on ANY car in the front is a lot bigger than the back? If u follow the curve of the wheel well/cavity from the outside, u will notice that the front is higher of the ground than the rear? I don't know if people notice this, but i do, and it bugs the hell outta me... can someone explain this to me? Are all the car designers drunk? I know the front wheel needs to turn and all but c'mon?!
Thx ahead of time... the question above is the reason when i plan to lower the front more than the rear... to make up for the bigger gap in the front...
[Modified by dclub01, 12:45 AM 3/28/2003]
Old Mar 27, 2003 | 03:42 PM
DrunkenPimp151's Avatar
Default Re: 18/19in rim size recommendation plz! (dclub01)
It's useless to have a different size rim in the front than the rear. You'll mess up your suspension geometry doing so. I doubt you'll be able to lower your car that much in the front with 18's and with 19's you'll rub. I've seen 19's on a Civic and EVERYONE said they rubbed.
Why do you want two different sized rims?
Old Mar 27, 2003 | 03:45 PM
Smith Wise's Avatar
I don't think 19s on a Civic will work without cutting the inner wheel wells. Not sure if you want to do that. I KNOW that if you put 18s and/or 19s on a Civic forget about dropping anything, in fact, you might need to raise it.
P.S. For asking this question, the H-T users will consider you a rice-boy. It sucks, I know it does, I've got 17s and I love it but to people on H-T, there's no need for such gigantic rims. It takes away from speed.
Old Mar 27, 2003 | 03:47 PM
dclub01's Avatar
Default Re: 18/19in rim size recommendation plz! (DrunkenPimp151)
So they are too big?! Raising?! Ack! Haha... i want to lower, not raise...
I'm going for show, not speed... i guess 19s are better on an accord?
Can someone ANSWER my question about the wheel well height thing?
[Modified by dclub01, 1:10 AM 3/28/2003]
Old Mar 27, 2003 | 03:50 PM
B_CRUZ!'s Avatar
gEt somE sPrEeweLL's dAwG!
Old Mar 27, 2003 | 03:55 PM
Default Re: 18/19in rim size recommendation plz! (Jswpstdoff)
MYTH....
Weight of the wheel makes more of a difference. If you have 17in rims that weight 11lbs and you compare them to 15in rims that weigh 17lbs, the 15in rims take more away from performance. This is all provided the diameter of the rim/tire combo stays around the same.
[Modified by DrunkenPimp151, 7:56 PM 3/27/2003]
Old Mar 27, 2003 | 04:00 PM
Smith Wise's Avatar
I mean tthe weight. Of course lighter is better. Excuse me ..................
MYTH....
Old Mar 27, 2003 | 04:12 PM
dclub01's Avatar
Thx for all the info!... now can someone answer my wheel well/cavity thing?
Old Mar 27, 2003 | 04:16 PM
euclid's Avatar
i have 17" oz superleggeras that weigh 15lbs, plus my tires are pound lighter than the 15" version, i like my 17's for street driving.
as far as 19's... not talking about the obvious... you will never be able to find a tire with a low enough profile, and you will not be able to lower your car. you will have rubberbands around those rims, they will be be bent to **** 10 minutes after you put them on.
Old Mar 27, 2003 | 04:17 PM
euclid's Avatar
you want to put 19's on a civic and you are calling the honda engineers drunks.
Old Mar 27, 2003 | 04:19 PM
viCeVerSa's Avatar
if there is a good reason which im not aware of to hold that setup on a fwd car someone please tell me
why oh why would you do that, the car is not rear wheel drive.... it serves no purpose at all putting larger rims in the back than in the front , just get 17s or 18s front and back.... it will be better riding and less of a bitch and less expensive... maybe with the leftover money you could put it towards an air lift or hydraulics... YEEEAAAHHH
[Modified by viCeVerSa, 1:24 AM 3/28/2003]
Old Mar 27, 2003 | 04:22 PM
Smith Wise's Avatar
Default Re: 18/19in rim size recommendation plz! (viCeVerSa)
I told you....................... most H-T users hate rims unless they're lightweight, or 15inches.
Old Mar 27, 2003 | 04:24 PM
FifthGearOnline's Avatar
go with some 16's
Old Mar 27, 2003 | 04:25 PM
slvrcivic97's Avatar
In my opinion, not trying to tell you to not put 18's or 19's on your car because it's your car, BUT, I think on an eg, the highest size you should go is 17 becuase anything more just doesn't look right on most eg's. Now on a 6th gen ek, I still think 18's or 19's are a little big, but they can usually get away with it more. But hey, anything can be done so if you want to slap 19's on an eg, I'm not stopping you, but it most likely won't look as good as you think it will.
viCeVerSa's Avatar
actually to the thing about big rims are bad for performance, youll get better gas milage on the highway haha but yeah i like 16s
Old Mar 27, 2003 | 04:27 PM
slomofo's Avatar
GDD Member
Won't rub if he manages to find 19x7 (Doubt he will) and runs a 205/35/19 OR if he leaves it at stock height
Old Mar 27, 2003 | 04:30 PM
dclub01's Avatar
Okay... okay... the 19/18s are out! Haha... jus wanted opinions...
Anyways, back to my question b4, maybe i didn't explain it well... but let me try...
[img=http://free.hostdepartment.com/b/blades5/wheel.jpg][/img]
Don't click on it, jus copy and paste in address bar...
This is a link to a very generic drawing about what i'm talking about, if u look at the picture, u will notice that the wheel well/cavity (whatever u want to call it) is a lot higher in the front than in the rear?! My picture is a little over-rated, but u get the idea...
I have drawn height marks in red for the front and the rear... can someone explain this to me? And if u think that the cavities are even, u are wrong, look closely at any car, even ur own and measure if u need to...
Can anyone explain? This is why i said car designers are drunk... it's of no relation to the rim size... thx alot!
[Modified by dclub01, 1:34 AM 3/28/2003]
[Modified by dclub01, 4:55 AM 3/28/2003]
Old Mar 27, 2003 | 04:31 PM
slomofo's Avatar
GDD Member
Your pic is forbidden.
Old Mar 27, 2003 | 04:35 PM
djthelo's Avatar
Default Re: 18/19in rim size recommendation plz! (slvrcivic97)
would 17's with 235/45 rub and could i put them on my 98 civic and not change the springs or shocks
dclub01's Avatar
Default Re: 18/19in rim size recommendation plz! (slomofo)
copy and paste... the host is not letting me link it...
Old Mar 27, 2003 | 04:37 PM
There is no way you will keep around the same diameter of the stock wheels if you go to 19in rims. He's going to HAVE to get 215/35/19 if he wants any chance in hell of the rims fitting, and with that combo you'll be well over the stock wheel diameter. They don't make 205/35/19's that I've seen. You'll be looking to spend AT LEAST $150 per tire if you go for that setup.
If you do want to go ahead and do it, you'll have to take out the fender lining and be VERY careful about what shocks/springs you go with. Even when you do that, you'll still not be able to go though your full turning radius and you'll rub going over bumps and turning. It's really not worth the trouble just for loks, unless of course you don't plan to drive the car at all.
Old Mar 27, 2003 | 04:40 PM
Default Re: 18/19in rim size recommendation plz! (djthelo)
If you go with a 235/45 tire the diameter of the wheel will be a little smaller than stock (stock is something like 25.5in and with a 235/45 it'll be 25.3) However with the added width (going to an 8in width rather than 7 or 7.5) you'll still rub, before you even lower the car.
slomofo's Avatar
GDD Member
Anything above a 205 will rub if you have the standard 2.5" drop that everyone else has, you could probably get away with 215/40/17's on Kuhmo Ecsta Supra's with a little bit of negative camber in the rear on rolled fenders, but I wouldn't advise making U-turns cuz it would rub in front.
I copied URL and pasted, but all I get is a page with some chicken scratch on it.
Old Mar 27, 2003 | 04:57 PM
djthelo's Avatar
how about a 205/45/17 setup?
i don't want tires thinner than 45's i would prefer 50's and i don't really want to mess with my suspension
Old Mar 27, 2003 | 05:28 PM
151 Proof's Avatar
The 45 in 205/45/17 isn't the tire width, 205 is the width in millimeters. The 45 is the aspect ratio, which you get by dividing the height by the width, of the sidewall that is. And the last number is obviosly the rim diameter in inches.
