Hondata intake manifold gasket $35
Lets get some support for this, same thing with out the hondata co$t.
https://honda-tech.com/zerothread?id=454646
eh...i just checked out the website (an-r.com). The guy JUST registered the domain and it's only good for a year. And it's freakin' based in Canada...home to most of the internet swindlers. US laws can't touch em.
Domain Name: AR-R.COM
Registered Through....: CheapDomainGroup
Created on............: 14/01/2003 03:15:02
Expires on............: 13/01/2004 11:04:09
Record last updated on: 14/01/2003 03:15:02
Owner, Administrative Contact, Technical Contact, Billing Contact:
Pierre Saint-Laurent (ID00020038)
47 Melbourne Avenue
Mount Royal, QC H3P1E9
ca
Phone: +1.5149988076
Email: psl@assetcounsel.com
Domain servers in listed order:
NS1.IPRIMUS.COM.AU 203.134.64.66
NS2.IPRIMUS.COM.AU 203.134.65.66
47 Melbourne Avenue
ca
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotaryBzzz »</TD></TR><TR><TD CLASS="quote">eh...i just checked out the website (an-r.com). The guy JUST registered the domain and it's only good for a year. And it's freakin' based in Canada...home to most of the internet swindlers. US laws can't touch em.
47 Melbourne Avenue
ca
first off, you got the wrong website. our is AN-R.com, not "AR-R.com"
also, do a search and ask around about us. i assure you that you will not hear a single bad thing about us. also, i think if i got approved by "Tony" the boss of best buy forum, it should be good enough. check what we have to go through to get approve and you will understand. you will also notice that there are many reputable shops that have not gotten approved yet because of Tony's standards.
47 Melbourne Avenue
ca
Has anyone actualy used this product or the hondata one? I'm curious about it's value.
<U>from the hondata site </U>
The graph above shows the results of installing the Heatshield gasket and bypassing the throttle body heating and idle control valve heating.
so the gain you see isn't just from the IM gasket, but also from the coolant bypass trick that a lot of us have already done. I'd like to see if it makes much difference by itself.
the other thing is that if the heat in the head isn't getting absorbed into the IM, then it is staying in the head. maybe that is ok, but if the temp of the head rises significantly, you would put additional strain on your cooling system, and make the motor more detonation prone.
I'm just thinking out loud here. maybe somebody can add something to this
patastinky
Dec 4, 2004 07:32 AM
sleepin91teg
Jun 20, 2004 01:05 PM
