h22a iab
Old Mar 27, 2003 | 11:04 AM
rabalero's Avatar
Default h22a iab
I have a h22a accord and I want to know if somebody knows where the IAB is located? cuz I have a small cillynder between the intake and the and the head and is not connected....and other thing is not connected is a big black box under the intake.....I read in other forums and some guys are saying that with the IAB disconnected im losing midrange power is that true?? and by the way how do you connect the IAB??????????????????
Old Mar 27, 2003 | 11:09 AM
Stew Pidasso's Avatar
Default Re: h22a iab (rabalero)
You are mostly losing low-low/mid end power with them unhooked. I'm not exactly sure where they are or what they look like but I will know this weekend. I'm pulling my H22A head off to be port & polished. What ECU are you using?
Old Mar 27, 2003 | 11:46 AM
CD8's Avatar
CD8
Default Re: h22a iab (Stew Pidasso)
yes you should run the IAB. you need it. im running it on my 93 h22a.
i cant really remember but i believe the black box under the IM is where the IAB hooks to.
Old Mar 27, 2003 | 12:39 PM
Nick M's Avatar
Default Re: h22a iab (exaccord)
its a small black plastic box looking thing, a couple vacuum lines connect to it, its necessary unless you are running an ATR manifold
Old Mar 27, 2003 | 04:28 PM
yun_cheezie's Avatar
Default Re: h22a iab (Nick M)
i sort of ran into that same problem with my 6 gen h22a. i'm currently in the process of gathering sensors (etc. dam j-spec motors, always have to have broken sensors...) anyway, the iab valve is mounted on top of the black box (vac box) with two vac fittings. one vac line goes to the iab valve (with a plastic one way valve in the middle) and the other to the intake manifold. the box is indeed located under you IM. with out it your intake manifold and related parts may not operate like they should (how bad, i dont know).
orville99
Apr 7, 2017 08:00 PM
jet3000gt
Jul 22, 2005 05:24 PM
Accord6Gen
Jun 30, 2004 04:49 AM
