Need a step by step guide to installing DSM 450's into a OBDII GSR
C'mon, somebody here knows how to do it! I dont even really need the step by step, I just need to know what I need to buy besides the injectors to make them work, and if someone could give me the lowdown on the wiring that would be cool too.
You'll need the following.
-DSM 450's
-clips to mate to the 450's
-some method of resistor. An old skool EF resistor pack will work. Also, 10w/10ohm inlines work well too (this is used to run a peak and hold injector in with your saturated type ecu)
Other than that, run the black wire to the black wire, and the colored wire to the colored one. Ensure that your resistors are also connected to the colored wire, and tune away.
-DSM 450's
MBlake55
Aug 8, 2007 07:29 AM
boostincoupe
Jul 30, 2005 07:32 PM
