adding a sway bar on a 88dx
The stock mounts on the frame do not have the internal nuts. A plate with the appropriate size nuts welded to it then cut out the holes in the frame large enough to allow the nuts to be recessed inside the frame. I used 1/4 inch plate. it lowers the sway bar mounts by 1/4 inch no big deal. On the control arms you will need to cut spacer tubes that will fit inside the stamped control arms. Then use a bolt long enough to go al the way thru the LCA and the sway bar bushing. Works like a champ and really makes a difference in handling. If you really want to make it flat in the corners use the Suspension Techniques Sway bars both 22 mm front and rear. That makes a night and day difference. Be sure to install both front and rear. Rear only, CAN YOU SAY OVERSTEER!!!!
I believe you're also gonna need 88 si LCAs because the stock DX LCAs do not have the mounting holes, might be better to go with an aftermarket sway bar...
I have a pair of DX rear LCAs and they already have the holes for mounting the sway bar. As I stated above the only addition would be a sleeve of the right lebght to keep the LCA from deforming based on bolting up the sway bar.
