to run low-mid 13's
Old Mar 27, 2003 | 07:36 AM
tsi_turboawd's Avatar
Default to run low-mid 13's
whats needed to run mid-low 13's on an ITR?
Old Mar 27, 2003 | 07:43 AM
Smitdog's Avatar
Default Re: to run low-mid 13's (tsi_turboawd)
I/H/E, 18 Deg Timing, Slicks and Weight Reduction.
Old Mar 27, 2003 | 08:01 AM
Chris N's Avatar
Default Re: to run low-mid 13's (Smitdog)
How much weight reduction are you talking about?
Old Mar 27, 2003 | 08:05 AM
py1188's Avatar
Default Re: to run low-mid 13's (Chris N)
I'm not sure weight reudcution can pull that much off, unless we're talking CF panels and lexan
But I've been wrong before
Old Mar 27, 2003 | 08:27 AM
MPH's Avatar
MPH
New User
Bigger cams
Old Mar 27, 2003 | 08:30 AM
(__________)'s Avatar
rip the AC and PS out too.
It should be fairly easy to hit high 13's with just bolt ons
Old Mar 27, 2003 | 08:31 AM
jond's Avatar
Default Re: to run low-mid 13's (steves98itr247)
Would just a set of drag slicks get a stock itr into the 13's?
Old Mar 27, 2003 | 08:34 AM
MPH's Avatar
MPH
New User
Default Re: to run low-mid 13's (jond)
Doubt it. Need a header at the least.
Old Mar 27, 2003 | 08:46 AM
typeR 507's Avatar
Default Re: to run low-mid 13's (MPH)
im going for 12' or better so i know i got to do alot more work but im going to keep it with stock inturnils mainly all bolt on and a nice ZEX 50 shot to go along with it
ALLMOTOR18's Avatar
I agree...
Old Mar 27, 2003 | 08:49 AM
SoCal ITR's Avatar
Default Re: to run low-mid 13's (gsrtyper)
I/H, no A/C and a good driver will net you high 13's
Old Mar 27, 2003 | 08:52 AM
zijiejijeijrkjk's Avatar
cheapest way?
slicks and nos setup
Old Mar 27, 2003 | 09:15 AM
MK Ultra's Avatar
Default Re: to run low-mid 13's (TypeR507)
I've always looked at nitrous as cocaine for your motor; fun, but not healthy.
Bolt-ons should get you close to the very upper edge of 13s. Just out of curiousity, why do you plan on using stock internals? It's really not that expensive to re-build a bottom end with upgraded pistons, which would be a good idea if you plan on using enough nitrous to get into the 12s. The stock pistons are fairly weak. You'll probably end up breaking the ring lands.
Any way you cut it, it won't be cheap to get your car into the 12s. You might as well do it right and forget about using all stock internals. Just my $.02.
[Modified by MK Ultra, 12:17 PM 3/27/2003]
Old Mar 27, 2003 | 09:18 AM
Default Re: to run low-mid 13's (MK Ultra)
spray it til you blow it then rebuild it
Old Mar 27, 2003 | 09:21 AM
MK Ultra's Avatar
That's what a lot of people do. Of course, you risk damaging more than the parts you want to replace.
Old Mar 27, 2003 | 09:28 AM
Eva01's Avatar
That is the phrase of the day right there! LOL.
Old Mar 27, 2003 | 10:09 AM
98cwtypeR's Avatar
Default Re: to run low-mid 13's (Eva01)
basic bolt-ons and stripped interior should be enough. I saw a guy at the track hit 13.8 with cams and stripped interior.
Old Mar 27, 2003 | 10:12 AM
Chris N's Avatar
Default Re: to run low-mid 13's (98cwtypeR)
You can hit high 13's with stock cams. Ask Active Aero.
Old Mar 27, 2003 | 10:17 AM
Smitdog's Avatar
JDM 4-1, Carosund Cat, Icebox, N1 and PS Belt off.................time and video in the signature............
Austin's Avatar
13.8 no problem with stock cams...I just need some better traction than the worn out Nitto tires I have, then I can hit some better times.
Austin
Old Mar 27, 2003 | 12:17 PM
SoCal ITR's Avatar
Default Re: to run low-mid 13's (Austin)
On stock cams, it's possible to run low 13's I'm sure.
EP is making at least 213 whp on stock cams.
Old Mar 27, 2003 | 02:24 PM
py1188's Avatar
Default Re: to run low-mid 13's (SoCal ITR)
Thats crazy!! Where can we find the most recent list of his mods?
Old Mar 27, 2003 | 02:37 PM
B00ST2nR's Avatar
Default Re: to run low-mid 13's (py1188)
Yes its do-able with the stock ITR cams... but with bigger cams, it will be MUCH easier.
Old Mar 27, 2003 | 02:47 PM
98itR484's Avatar
Pick up mOOgens catolog, that list is his list of mods
Arno-who cant wait for the expo to see the mOOgen mObile in action
Old Mar 27, 2003 | 03:07 PM
vtec.dc2's Avatar
get turbo and run that all day long.. you probably need close to 200whp to accomplish that.. Activeaero might make it with -10 whp from 200.
