taking off front bumper.
Old Mar 27, 2003 | 06:50 AM
One2chi's Avatar
Default taking off front bumper.
taking off my 5th gen front bumper in about 5 mins. how many bolts should there be? i took it off once before and i rmeber there being more than i expected.
last time i had help, anyone think i can take it off and pout it on (straight) by myself?
Old Mar 27, 2003 | 07:00 AM
jokerstud's Avatar
Default Re: taking off front bumper. (One2chi)
for the most part there is only 4. lots of little stuff connecting the bumper to other parts but just 4 main bolts
Old Mar 27, 2003 | 07:20 AM
One2chi's Avatar
Default Re: taking off front bumper. (jokerstud)
do i ahve to take the lip off to take off the bumper or wil lthe lip come off with it?
Old Mar 27, 2003 | 08:12 AM
DeJaVu's Avatar
as far as I remember, 4 supporting bumper bolts behind the bumper signal and 2 on the sides, under the fender.
I hope my memory serve my correctly
Old Mar 27, 2003 | 09:06 AM
ZZZaCcOrD's Avatar
It is kind of a bitch to take off your front bumper on a 5th gen. To do it "correctly", you must take the headlights out because their are two screws under each headlight that can't be reached without the removal of the headlights.First, remove the grill ( 5 screws) The easiest way to remove the headlights is by unscrewing the bumper support screws. After you do this, the support will slide down but wont fall off. Then their should be a total of 5 screws on each headlight that must be removed to get the headlights out. Then, their is a screw on each side of the bumper that hold the bumper and fender together. Then unscrew the screws that hold the bumper cover on. ( I think 7 or 8). That should be it. Trust me this is right because I just recently replaced my whole front end including fenders and headlights due to an accident. Don't try to remove the bumper cover without the headlights out. Do it right so nothing gets broken and so it also is sturdy.
Old Mar 27, 2003 | 09:13 AM
Accord_Munch's Avatar
Default Re: taking off front bumper. (ZZZaCcOrD)
Um .. you can't take the headlights out .. unless you have the front bumper off to begin with ... but I think you were referring to the bumper lights, because you need to remove those to get to the two bolts behind there (Main support bolts for the front bumper).
[Modified by Accord_Munch, 10:14 AM 3/27/2003]
Old Mar 27, 2003 | 11:17 AM
ZZZaCcOrD's Avatar
Default Re: taking off front bumper. (Accord_Munch)
Actually, when you remove the grill and the bumper support bolts (2), the bumper slides down and gives you plenty of room to access the 5 blots for each headlight and to take out the headlights. Even when the bumper cover is off, you still can't remove the headlights unless you drop the bumper support under the bumper cover. The bumper cover is just that, it is only a cover, I know what I am talking about because I just did the **** on my accord not to long ago.
Old Mar 27, 2003 | 11:19 AM
ZZZaCcOrD's Avatar
and the main support bolts for the bumper cover are not behind the corners. Those bolts connect rhe fender to the chassis, they have nothing to do with the bumper. And the bumper cover does not have bolts. They are little screws. The bumper support bolts are behind the cover by the horns.
Old Mar 27, 2003 | 11:10 PM
Heat's Avatar
Slightly off topic, but how about taking the back bumper off of a 1999 Honda Accord (6th generation?) ? A girl hit me in my back quarterpanel last fall, and I see now that it is rusting back there (behind the bumper), and I wanted to scrape it down and coat it with touchup paint. It doesn't have to look pretty since it is hidden behind the bumper, but I don't want it rusting, of course.
ryan_crx
Apr 24, 2009 07:42 AM
jjokerzwild
Jul 22, 2006 01:26 PM
91STD
Nov 28, 2004 07:37 AM
LudeyKrus
Jan 22, 2003 05:49 PM
