Bigger fuel pump on N/A engine? Lack of fuel to my CRX...fuel problems
Old Mar 27, 2003 | 05:56 AM
RacerBoy's Avatar
Default Bigger fuel pump on N/A engine? Lack of fuel to my CRX...fuel problems
It seems that my Z6 engine in my CRX is not getting enough fuel it needs. I just recently installed a DC 4-2-1 and greddy cat back. It seems at low rpms it bogs a bit. I just changed over from 87 octane to sunoco 94. What precautions should I take to change this situation. Should I change my fuel filter? WHere and how do I do it? Change my fuel pump to an aftermarket one? Any advice would be great guys
Old Mar 27, 2003 | 08:45 AM
EF_LSVtec's Avatar
Default Re: Bigger fuel pump on N/A engine? Lack of fuel to my CRX...fuel problems (RacerBoy)
how sure are you that your motor lacks fuel? for stock motor with basically little mods, you can start by tuning it up and advance the timing a bit if you think it bogs...If you decide to get an aftermarket fuel pump, get a fuel regulator and gauge too.
Old Mar 27, 2003 | 07:35 PM
RacerBoy's Avatar
Default Re: Bigger fuel pump on N/A engine? Lack of fuel to my CRX...fuel problems (EF_LSVtec)
bump
Old Mar 27, 2003 | 08:05 PM
Urban Business
Guest
Posts: n/a
change your fuel filter, use some injector cleaner. you have the means to give it more than ample fuel. your a/f ratios all fuct? your egt hot as ****? how do you know its not getting fuel.
sasinorm01
Mar 19, 2015 09:28 AM
Golding.racing
Apr 26, 2013 12:26 PM
crnimacak
Apr 21, 2006 10:11 PM
eg6_lsi
Mar 25, 2004 10:29 PM
dustin
Feb 8, 2002 06:41 PM
