Need help temp. problem 95 accord
Old Mar 26, 2003 | 10:39 PM
sharktlp's Avatar
Default Need help temp. problem 95 accord
my accord is over heating too much and i dont know why i changed the radiator thinking it was that. It over heats when idling then when i hit the gas it cools a bit but today it over heatd and started smokin in just 5 mins of driving.
Old Mar 26, 2003 | 10:58 PM
accordfreak's Avatar
Default Re: Need help temp. problem 95 accord (sharktlp)
change your thermostat
bleed your coolant system
Old Mar 27, 2003 | 12:00 AM
AsiAnVenOm's Avatar
Default Re: Need help temp. problem 95 accord (accordfreak)
change your radiator cap...
Old Mar 27, 2003 | 06:16 PM
95 GaNgStA AcCoRd's Avatar
Default Re: Need help temp. problem 95 accord (AsiAnVenOm)
search a few pages back
Old Mar 27, 2003 | 11:34 PM
Qfactor's Avatar
Default Re: Need help temp. problem 95 accord (95 GaNgStA AcCoRd)
it's probably too late. warped head, head gasket or cracked head. do a C02 test or leak down test. here's a test to do with out these two test check take your spark plugs off and look inside the and check the piston domes if one of them usually #2 or #3 will be clean and others will be black or take rad. cap off and let it idle for about 5-8 min if water starts bubbling then you know.
Old Mar 28, 2003 | 06:19 AM
Superorb's Avatar
Default Re: Need help temp. problem 95 accord (Qfactor)
thermostat. if its been doin it for a while kiss yur head goodbye
thasickness
Sep 26, 2015 03:47 PM
Bilster
Nov 8, 2014 06:58 AM
youdntcme
Jul 28, 2013 07:12 AM
rmason1
May 13, 2013 09:53 AM
dwilson
Nov 19, 2010 08:37 AM
