Anyone running an electric water pump?
Old Mar 26, 2003 | 10:09 PM
XES's Avatar
XES
Default Anyone running an electric water pump?
Anyone here running an electric water pump? If so...what kind, and how much more efficiently does it cool the motor, etc.
Old Mar 26, 2003 | 10:51 PM
B18EG6's Avatar
Default Re: Anyone running an electric water pump? (XES)
bump. interested too
Old Mar 28, 2003 | 09:12 AM
XES's Avatar
XES
Default Re: Anyone running an electric water pump? (B18EG6)
no one?
Old Mar 28, 2003 | 09:15 AM
94TealGSR's Avatar
If the archived search ever returns there was a long post in the integra forum by some people that were running them. They were having problems as I recall. They had to drill holes in their thermostats for some reason... that's all I remember. Sorry
Old Mar 28, 2003 | 11:55 AM
b18bturbo's Avatar
Default Re: Anyone running an electric water pump? (94TealGSR)
i used one on the drag setup fine never had any issues cooled fine
Old Mar 29, 2003 | 03:56 PM
B18EG6's Avatar
Default Re: Anyone running an electric water pump? (b18bturbo)
did you drill holes in the thermostat? or pt a restrictor plate in there? Have any problems with burning out the motor of the pump?
Old Apr 5, 2003 | 06:06 PM
XES's Avatar
XES
ttt
Old Apr 5, 2003 | 06:14 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
I run one in my racecar. Cools great, no thermostat tho, car has to warm up for a while, i dont know how efficient it is on a streetcar since mines only driven about 20 minutes a month
Old Apr 5, 2003 | 07:08 PM
BoostedH23a1's Avatar
Default Re: Anyone running an electric water pump? (SIXTYdashONE)
you would have to leave the stock one on there right... due to timing belt length.. what would the point be...
Old Apr 5, 2003 | 08:06 PM
rioninja's Avatar
The electric pumps i've seen that were honda specific usually come with a dummy plate that takes place of the stock pump, which has a gear on it.
From what i 've heard, they actually cool too well for street cars.
Old Apr 5, 2003 | 08:47 PM
HT's Biggest Loser
Default Re: Anyone running an electric water pump? (rioninja)
yes, the stock pump is removed, and a dummy plate is put in its place. The car runs REAL cool with it, streetcar or whatever the application
EDIT: Keep in mind, the dummy plate that is on the timing belt will put less strain on the belt, freeing up some extra power.
[Modified by SIXTYdashONE, 5:51 AM 4/6/2003]
Old Apr 6, 2003 | 06:26 PM
XES's Avatar
XES
What about the thermostat? Is it required to take it out, or should holes be drilled (and if so how big, etc.)?
ranta18
Nov 12, 2009 08:04 AM
kndaqikEG
Jul 29, 2005 03:04 PM
b16supertuner
Jul 14, 2003 06:17 PM
DC2Monster
Feb 8, 2003 01:17 PM
