Legend brake swap
Old Mar 26, 2003 | 08:57 PM
cam0693's Avatar
Default Legend brake swap
I have been trying to access the archive for about a little over a week and it wont work....i had printed out some great directions on how to do a legend 2 piston swap on to a 97 accord... but i cant find it and i cant remember what I had to buy
so far i have the v6 rotors...not sure what caliper brackets to get??? if anyone can help me with a link or if they have to instructions saved please email them to me or post them in this thread......thanks
Old Mar 26, 2003 | 09:22 PM
OEMaccord's Avatar
Default Re: Legend brake swap (cam0693)
http://www.accordinglydone.com/tech.php?ID=32
http://www.accordinglydone.com/forum/
Old Mar 27, 2003 | 05:46 AM
cam0693's Avatar
Default Re: Legend brake swap (OEMaccord)
in the how-to's the guy said to use a 23t bracket but on one of the threads they say that the 23t bracket was to small???
Old Mar 27, 2003 | 05:51 AM
Gennady's Avatar
New User
23T will be ideal. 25T will also work fine.
Old Mar 27, 2003 | 06:05 AM
Martaigne's Avatar
Default Re: Legend brake swap (Wont be beat)
It depends on your rotor thickness. Most seem to be 23mm thick, thus a 23T bracket will work just fine.
Old Mar 27, 2003 | 06:08 AM
cam0693's Avatar
so all that is needed is the v6 rotors and legend calipers which i have...and to get a 23t bracket? anything else??
thanks for all the help
Old Mar 27, 2003 | 06:28 AM
Drews Bitch's Avatar
where can you find these brackets? are they a dealership only part?
Old Mar 27, 2003 | 07:23 AM
Superorb's Avatar
Default Re: Legend brake swap (shepworldwide)
i have some sitting at the shop, still waiting on an easy out to get one damm bolt holding the plate to the hub and the rotor is sandwiched bn, gota love 5th gen accords...
i have the 28T bracket and everyone i talked to said to use that bracket...
im using av6 rotors as well... will i need 23t or 25t brackets?
Old Mar 27, 2003 | 09:13 AM
Martaigne's Avatar
Default Re: Legend brake swap (Superorb)
You can use any of the brackets, but the bigger the bracket the more brake travel before you contact rotor.
Old Mar 27, 2003 | 09:21 AM
Superorb's Avatar
Default Re: Legend brake swap (Martaigne)
ohhh, ok. well, what would be the most ideal bracket if im using the av6 rotors on my accord?
hey, i hear u know greensleeper, can u vouch for him?
ken
Old Mar 27, 2003 | 09:31 AM
Gennady's Avatar
New User
23T as stated earlier.
Old Mar 27, 2003 | 09:46 AM
GZERO's Avatar
what would be the thickness of the AV6 discs?
Old Mar 27, 2003 | 10:19 AM
Superorb's Avatar
so if i use the 23T bracket will i need the spacers like i should use w/ the 28T bracket?
Old Mar 27, 2003 | 11:12 AM
Gennady's Avatar
New User
You got it backwards.
Old Mar 27, 2003 | 11:24 AM
Superorb's Avatar
av6 rotors are 25mm thick.
got what backwards..
Old Mar 27, 2003 | 01:24 PM
Gennady's Avatar
New User
You got that backwards.
Again, it will all depend on the rotor thickness. If its 25mm, try and find a 25T bracket from an Accord V6 or something.
Old Mar 27, 2003 | 01:36 PM
Superorb's Avatar
ohh, i think i got it. if i use 25mm otors, ima need 25t brackets. if i use the stock accord 23mm rotors, ill need the 23t bracket... i think i got it now what car uses the 28t bracket anyways...
and what cars use the 25T bracket besides the av6. and i thought that the 4th gen ludes had the 25mm rotors...
[Modified by Superorb, 6:21 PM 3/27/2003]
Old Mar 27, 2003 | 03:08 PM
Gennady's Avatar
New User
The Odyssey and possibly the MDX/Pilot use 28T brackets.
4th gen Prelude use 23mm rotors.
Old Mar 27, 2003 | 03:47 PM
redvic's Avatar
Does anyone know if you can put the legend brakes on a 90 accord
Old Mar 27, 2003 | 04:01 PM
Gennady's Avatar
New User
Default Re: Legend brake swap (accvolks)
Well, 2-piston Legend calipers will bolt up to about 4 different brackets. Those brackets will bolt up to the knuckles of your car. You cant use applicable Legend rotors however.
Old Mar 27, 2003 | 07:51 PM
Nick H's Avatar
New User
has anyone here done this, if so how much of a difference is there with the larger brakes...i just want to make sure it's noticable, because it's a little pricey...
Old Mar 27, 2003 | 09:42 PM
Superorb's Avatar
ok guys, i just got back from the garage and i test fit the pads and rotors. im using legend twin piston calipers and the 28T bracket, and soem av6 rotors, 11.1" diameter/25mm thickness. it looks as though there is about 3-4mm clearence bn the pads and the rotor, when the piston is fully in the caliper. therefore, if u used the 25T bracket it would be PERFECT for these rotors. but, if u dont, u will have like 3mm of extra travel on the calipers, which should NOT be a problem at all. if yur leary, go find some 25T brackets, although these are extremely rare to come by. you wont need a spacer if u use the 28t bracket and the av6/wagon rotors. this is all going onto a 5th gen accord 4cyl, stock knuckles and suspension for the brake swap...
Old Mar 27, 2003 | 09:57 PM
TypeSH's Avatar
considering the calipers are sliding calipers, wouldnt they self-adjust even with 28T brackets on 25mm rotors? either way 3mm of diff is not as bad as 5mm diff for those using 28T brackets on 23mm wide rotors.
Old Mar 27, 2003 | 10:01 PM
Superorb's Avatar
Default Re: Legend brake swap (TypeSH)
ya, i agree, specially since as long as u bleed the brakes w/ them on the rotors, u should be fine as far as pressure loss is concerned, and about 3mm is nothing, thank god i got those av6 rotors... im just wondering about the size differnece in the 10.2 accord vs the 11.1 av6 rotors...
Old Mar 28, 2003 | 07:41 AM
toadlax's Avatar
sorry, im confused is this four lug or five?? anyone done this on a 6gen??
