Drag Gen 3 Kit / T3/T4 Oil Drain Flange BROKE!!!!
Where can i find a replacement oil drain flange...i installed a new steel braided oil return line kit i got from Stan on this board. Great kit...but i tightened the adapter that goes in the oil drain flange too tight and cracked the flange in half!!
Anyone know where i can find a replacement flange??? Need it in a hurry..
Thanks!
Take care.
Thanks!
Take care.
http://www.cheapturbo.com
I did the same thing..it cracked on one side. I just left it and put some jb weld on it. No leaks here.
I had the same problem. If its a Turbonetics Turbo call (805)581-0333 and they'll direct you to the nearest dealer that has it in stock. Also be careful that the flange is square because it will leak like crazy! No Hondabond will fix that leak.. Hope that helps you.
