i have everything for my swap(b18a in a crx hf 88) what else do i need to do?
Old Mar 26, 2003 | 03:36 PM
pdiddyparsons's Avatar
Default i have everything for my swap(b18a in a crx hf 88) what else do i need to do?
i have a 88 hf crx and i am dropping a b18a in it i haer4,teg axles,teg intermediate,teg knuckles,shift linkage teg,mounts ,motor tranny,clutch,flywheel,pressure plate,manifolds,teg wire harness,and hf wire harness,what else do i need and what do i have to do to the wire harness i have to make it work!!
Old Mar 26, 2003 | 03:43 PM
Blaze45's Avatar
Brrraaaap!
Default Re: i have everything for my swap(b18a in a crx hf 88) what else do i need to do? (lilparsons)
your rad hoses (upper & lower) , thermostat, water pump t belt, alt belt & resurfaced flywheel.
Good Luck
Blaze
Old Mar 26, 2003 | 04:22 PM
Flexmyrex's Avatar
sounds good to me, got the rear mount bracket?
the teg harness isnt gonna work, i dont know much about the hf harness but if its the same as the si use that. i used the si harnes cuz the ls harness had an extra plug which couldnt be pluged in, or the si harnes had an extra plug i forget
Old Mar 26, 2003 | 05:13 PM
riceboyEFsi's Avatar
Default Re: i have everything for my swap(b18a in a crx hf 88) what else do i need to do? (flexmyREX)
use the hf harness
hondaex99
Oct 29, 2009 09:19 PM
lemongreenhatch
10
Dec 12, 2004 10:11 PM
KevronsEG
Nov 20, 2003 07:57 AM
Serdar
Aug 15, 2003 08:05 PM
