97 DOHC Del Sol rear discs swap fit 89 CRX si?
Just as the topic says.... who knows for sure if a rear disc set-up from a 97 DOHC Del Sol will swap over to an 89 CRX si..... Did these del sol's come with ABS? if so will it be a problem being that the CRX doesn't have ABS....
com'on guys somebody's got to know... I tried to search but archived search function is disabled right now....
yeah they will work, about the ABS you can just unbolt the sensors and take them out, you cann't use them. Everything else is the same. The e-brake cables I cann't GTD they may but you'd have to test that your self, if not best bet is 90-91 CRX SI's
Thanks for the info.....I appreciate it. Is it a PITA to remove those sensors.... or fairly simple....
Oops, just saw that you said you just unbolt them.... can't get any easier than that..thanks again.
[Modified by CrxSi707, 7:48 PM 3/27/2003]
[Modified by CrxSi707, 7:49 PM 3/27/2003]
brohonda
Aug 2, 2017 11:59 AM
memphisraines26
Jan 16, 2003 07:43 PM
