S-AFC install, need help with pressure signal?
Old Mar 26, 2003 | 12:58 PM
luderone's Avatar
Default S-AFC install, need help with pressure signal?
hello, I have a 92 honda prelude with a f22a1 engine, I'm turboing the car, I'm installing the S-AFC. I got all the wires hooked up, but when I look to hook up the pressure signal, its not there in the ECU. its an empty pin on the plastic block. It should be the yellow and white wire on the AFC. I'm using the H2-a ECU wiring diagram in the apexi book. Do i need the pressure signal, please help, ,thanks ray
Old Mar 27, 2003 | 10:42 AM
luderone's Avatar
Default Re: S-AFC install, need help with pressure signal? (luderone)
anyone??
fiftee_su
Aug 3, 2005 07:11 PM
marieT1GRL
Mar 12, 2004 03:11 PM
turbolude92
Dec 26, 2003 03:06 PM
aracer69
Dec 19, 2003 05:12 AM
luderone
Apr 1, 2003 08:43 AM
