Sticker application
Old Mar 26, 2003 | 08:50 AM
clm's Avatar
clm
Default Sticker application
OK, I just got my parking permit for college. Now most schools would just give you a tag for your rearview mirror or a tiny sticker, well they use big ones that are size of index cards.
Now, I don't really like having stickers on my car and hope to remove the sticker after each quarter when I have to buy a new one. It doesn't look like it'll easily come off after applied, so is there a trick I can use when putting it on? Something similar to using wax when putting tape numbers on the body for track events. It also says taping it the window is prohibited, but I may end up doing that anyway.
Old Mar 26, 2003 | 09:16 AM
elwood's Avatar
Default Re: Sticker application (clm)
What if somone steals it? I say just put it on.
Old Mar 26, 2003 | 09:36 AM
rodrez.'s Avatar
You can't tape it to the window, but what about sticking it to the window on the outside. You can just use a razor to pull it off later.
Old Mar 26, 2003 | 10:20 AM
Ponch's Avatar
just put it on. I use a razor to get mine off at the end of each semester. Any glue left behind comes off with goo gone. works perfect. put it on the windshield in one of the lower corners. it's hidden there a little bit. won't take away too much from your ride.
Old Mar 26, 2003 | 11:01 AM
BoxStuffer's Avatar
Default Re: Sticker application (1.8L)
tape it to the inside of the window, and if you want to - get a permit pouch.
it's like a clear plastic covering you can slide it in that has suction cups to stick to the inside of the window... thats what i do
They also sell some sort of clear sticker that's not as sticky for you to put your stickers on and then apply to your window. I hope that made sense. It's specifically made for stickers that need to be applied to your car.
Old Mar 26, 2003 | 11:14 AM
clm's Avatar
clm
Default Re: Sticker application (ekcoupe97)
Well the sticker is made to put on the outside of the car. I just don't really want to deal with getting the residue off later; and it's so big. The "pre-sticker" stuff that ekcoupe97 mentioned sounds like a good idea, too.
I suppose I still have until Monday morning to figure out what I'm going to do. Thanks for the help.
0ptimus prime
Mar 16, 2004 09:37 AM
m0dr0cker
16
Oct 21, 2003 09:55 AM
yellowbuffalo
Aug 16, 2003 01:33 PM
gokuson
Jun 21, 2002 01:24 PM
