Tranny/clutch help!
Old Mar 25, 2003 | 10:18 PM
CRXGSR's Avatar
Default Tranny/clutch help!
So here's the story. I was replacing a tranny (from 89DX to 90 Si). At the same time I replaced the flywheel/clutch/pressure plate to the 90 Si.
Now that everything is installed, when the engine is off, it shifts into gears like normal, but when the engine is on, it's really hard (have to force) to get it into gear.
I also noticed that when the engine's on, and it's in gear, and the clutch pedal is pressed down, the car still continues to go move.
The clutch at the time still looked like it had a lot of beef left on it. Could the problem be the pressure plate? I did notice some heat spots on both the pressure plate and flywheel. Thanks in advance.
Old Mar 26, 2003 | 05:26 AM
mbsi's Avatar
Default Re: Tranny/clutch help! (CRXGSR)
release bearing?
Old Mar 26, 2003 | 05:50 AM
SiR Kid's Avatar
New User
Default Re: Tranny/clutch help! (mbsi)
Adjust your clutch.. it's to tight now, you need to loosen that round plastic nut thing on the cable to that the clutch release arm sits farther down when the pedal is not pushed.
Old Mar 26, 2003 | 11:01 AM
Flexmyrex's Avatar
Default Re: Tranny/clutch help! (SiR Kid)
yep adjust the cable, i had the same problem once
91crx-jace
Jan 11, 2009 06:41 PM
illack91
Oct 4, 2008 12:21 AM
confidence
Oct 23, 2005 04:21 PM
