Removing EGR?
Old Mar 25, 2003 | 09:15 PM
jdmcivicferio's Avatar
Default Removing EGR?
I remember reading about a prelude member who tricked his ecu into thinking his EGR system was there, but he removed the EGR system. I remember he used like a 160ohm resistor, I tried searching for it but couldn't find it, anyone remember this tread? anyone remember, thanks
Old Mar 25, 2003 | 09:35 PM
Que_Lude's Avatar
Default Re: Removing EGR? (jdmcivicferio)
Just block off the opening with sheetmetal and replace your erg.
Old Mar 25, 2003 | 09:42 PM
Elkins911's Avatar
Default Re: Removing EGR? (Que_Lude)
why would you wanna remove your egr? less gas milage if you do, and your car runs alittle poor too.
Old Mar 26, 2003 | 05:44 AM
93ludeSi's Avatar
Default Re: Removing EGR? (Elkins911)
Yeah, you can use a plate to block off the egr completly, but you will get a cel, I run type r egr valve, it recirculates the gas out, instead of reusing it
Old Mar 26, 2003 | 06:01 AM
rjr162's Avatar
you'd need a little more than 1 resistor, and the resistance is up around 1.2K Ohms between the 1st and 2nd pins, and around 2.8 between the 2nd and 3rd pins, and some other resistance between pins 1 and 3. It's like a giant POT and it's not that easy to get the resistors to work (I tried at one point and it seemed to work for a while, but going up a mountain "hill" i got a CEL indicating misfire on cyl 3 with a loss in power (limp mode of course)..). It's not worth it. Leave the EGR in and block the flow with a plate if you want to by-pass it
Old Mar 26, 2003 | 07:32 AM
fastludeh22's Avatar
why would you run poor? it stops hot air from going into your intake.
when you block it w/a plate, just reconnect everything like normal, the ecu will think its working, but the plate wont let anything though.
Old Mar 26, 2003 | 08:34 AM
MaxPower's Avatar
Default Re: Removing EGR? (fastludeh22)
I did it. The gains are non-existent.
The NOx emissions that EGR's reduce cause acid rain and global warming.
Spawne32
Mar 14, 2012 07:34 AM
FormulaIntegra
Oct 15, 2009 02:04 PM
seelyd
Dec 26, 2006 05:00 PM
soon2b
May 24, 2004 04:20 PM
