raditor swap...
Old Jun 15, 2001 | 04:24 PM
EvlErn69's Avatar
New User
Default raditor swap...
does anybody know what kinda of radator could be swapped in a crx.. plus for the swap i need some space for my b18 eng too.....
[Modified by EvlErn69, 5:48 PM 6/27/2001]
Old Jun 27, 2001 | 08:49 AM
EvlErn69's Avatar
New User
Default Re: raditor swap... (EvlErn69)
IS ANYBODY GOING TO RESPONED????
Old Jun 27, 2001 | 09:19 AM
crux131's Avatar
Sorry, don't know!
At least I responded!
Nah, this forum is a little slow from time to time, give it a while.
Nevermind, just reread your post dates, you have been giving it a while(DAMN)!
Try http://www.resource.crx.org
good luck
[Modified by crux131, 12:21 PM 6/27/2001]
Old Jun 28, 2001 | 09:42 AM
riceboyh8ter's Avatar
New User
Default Re: raditor swap... (crux131)
you can swap a b16a rad in that bad boy with little modification. the one from the 94-97 delsol v-tec, or the 99-00 Si i think both those will kewl the b18c1 fine... and get outta the way for a turbo or sum nice headers. also try removing the zc components i dont know about you but I think the engine bay in a honda looks so much cleaner after the ac is gone, but thats just me
Old Jun 28, 2001 | 10:15 AM
eg6ajk's Avatar
Default Re: raditor swap... (riceboyh8ter)
90-3 integra do fit...some are dual core....but some mods will be required...to fit a 92-5 civic rad, welding and cutting will be requiered...
Old Jun 28, 2001 | 12:16 PM
WuShu's Avatar
New User
Default Re: raditor swap... (eg6ajk)
i believe you can stuff a dual core radiator in there. This is what i want to do to make room for a turbo. You will have to custom fabricate radiator mounts though. I heard that this will even cool your engine better than the stock one. but honestly either way you go you will still have the same amount of space in teh bay. if you go with the stock radiator it is longer but thin so it gives you space to work with, if you go with a dual core it will free up some space on the drivers side front right behind the headlight but it is thicker so you will reduce space behind the passenger side light. I have heard that you if you take out the ac, you can move up your radiator forward more to give you some space but i am not positive. anyone know about this?
[Modified by HondaCRX, 9:17 PM 6/28/2001]
Old Jun 28, 2001 | 02:34 PM
raene's Avatar
Default Re: raditor swap... (HondaCRX)
I believe the radiator of choice is the Del Sol VTEC radiator, which is a dual-core design with metal endtanks. Not too sure about the endtank bit, though . Also, you could get a Fluidyne radiator or a Toyo radiator, both of which are much better than the OEM CRX radiator. The Fluidyne in particular is guaranteed to cool WHATEVER you're running whereever you're running, be it turbo, NOS, supercharger, or any combination of the above. I think it goes for $500.
country4life21
Honda Civic (2006 - 2015)
28
Jun 16, 2009 04:32 PM
monetcopy
Honda Civic (2001 - 2005)
May 28, 2009 12:26 PM
Littletrim7
Sep 18, 2003 02:57 PM
zer0zer0 TypeR
Aug 4, 2002 07:24 PM
