fuel pump install?
its easy. drain the gas, disconnect hoses snd electrical, drop the tank and pull out the pump.
Its not that bad (unless you dont like work) loosen the 2 holding straps, get a 2x4 and place it on a jack and raise the jack, lower it and loosen the connectors and 2 hoses then 8 bolts remove pump. Install is reverse. You dont have to drain the tank I did it almost full but the drain hole is pretty accessable its on the driverside in the rear of the tank, may have road grime on it but its there
b18da9
Jul 6, 2009 08:16 PM
