How do you adjust/aim headlights on 92 Accord?
I need to adjust them because one is shooting higher than the other. However, they don't have those headlight adjusters with watter bubbles like on the Integras. Any help will be appreciated.
I've seen to many people break their headlights trying to adjust them on their own to give you advice. Get a shop to do it...you don't wanna buy new headlamps.
OK bro...park your car on level ground pointed at a wall of some sort. there should be a screw adjustment just below the core support on each headlight housing. use the headlight that you believe is adjusted correctly and tighten or loosen the screw to align other beam....your headlight will not break
he's right..its pretty simple...just need a screwdriver and a flat road...ive heard that you should adjust your lights to where they cross and hit the road 20-30 feet out...thats about the average....real simple process...dont know how you could break the headlights...
That's what I'm saying....I HIGHLY doubt someone can break the headlights adjusting them unless they were a real moron. I adjusted the ones on my Integras and they were easy as hell. Anyways, thanks for thelp.
Kyles ej1
16
May 20, 2005 12:50 AM
