Aria pistons, ring end gap? tony1?
Old Mar 25, 2003 | 02:50 PM
boostaholic's Avatar
Default Arias pistons, ring end gap? tony1?
What are you guys using for ring end gap on arias pistons? I used .005" x bore size (3.206") for the top rings and all of them were in spec. Moved onto the second rings and measured them. The gap was less than .010" which seems kinda tight, about .003" per inch of bore. Even JE rings call for .005" per inch of bore on the top rings and .0055" per inch of bore for the bottom rings, so it looks like i'm gonna need to file these rings down a bit. These clearances are based on a motor that will be daily driven and weekend races pushing ~350-400whp.
Tony1, i know you use Arias pistons exclusively on the race car so hopefully you can shine some light on this.
[Modified by boostaholic, 5:52 PM 3/25/2003]
Old Mar 25, 2003 | 08:26 PM
tony1's Avatar
Default Re: Arias pistons, ring end gap? tony1? (boostaholic)
Use the specs given with the rings. If i remember right, it's bore x .006 for the top ring and bore x .0045 for the second ring. It's normal to have to file them.
Old Mar 25, 2003 | 09:43 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Arias pistons, ring end gap? tony1? (tony1)
damn tony, good memory!! I think you are dead on unless i forgot after just doing it 4 hours ago on our h22. ours we didnt have to file though but thats for a full race motor.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
cyanid3
May 30, 2014 10:36 PM
95blackEG
May 23, 2007 02:50 PM
MatHadder
Nov 19, 2006 11:04 AM
B19CivicHB
Jun 19, 2003 04:15 PM
