I have 4 Apex Turbo kits for sell. $1300 92-95 EGs.
Old Mar 25, 2003 | 12:26 PM
bluesaint's Avatar
Default I have 4 Apex Turbo kits for sell. $1300 92-95 EGs.
Apex kit . $1300..
(MODS, help me move to Forceinduction classified, i posted b4 I rememebred about the FI classified)
AX53B60 Turbo Upgrade
1992-95 Honda Civic EX or Si (D16Z6) - up to 160hp street, 190hp offroad
Includes:
EAX53B60 P18 ball bearing turbocharger
ECast-iron exhaust manifold
EPower Intake filter kit
ENecessary piping and mounting hardware
Car: // 1992-1995 Civic EX/Si (D16Z)
Product: // APEXi Civic Turbo Kit
Boost: // 6 psi stock, 5 psi w/intercooler
The "core of power" in APEXi's Civic turbo kit are an IHI AX53B60-P18 ball-bearing turbo and cast iron manifold. Cast iron is more capable of withstanding the heat generated by a turbo and can better position the turbo when compared with tubular manifolds, which can warp and crack in a turbocharged environment.
The IHI turbo uses its ball bearing center section to speed spool-up, which allows APEXi to be more aggressive on housing and wheel sizes, resulting a turbo that is responsive and provide good top-end flow.
Test Power Torque Hp Gain Tq Gain
Baseline 110.4 92.6
APEXi Turbo Kit 171.4 132.0 61.0 39.4
APEXi Turbo w/intercooler 186.8 141.7 15.4 9.7
Total Power Increase 76.4 49.1
[Modified by bluesaint, 9:32 PM 3/25/2003]
Old Mar 25, 2003 | 12:31 PM
Happyman's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (bluesaint)
What's the max psi for the turbo? Will it fit a y8?
[Modified by Happyman, 4:31 PM 3/25/2003]
Old Mar 25, 2003 | 12:37 PM
bluesaint's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (Happyman)
This kit is for 1992-1995 Civic EX/Si (D16Z) only. I think 6PSI is all you want to run unless you upgrade the fuel system and management. After that I know people who ran 8psi or probably more depending on your cooling setup and ECU management. This kit for the most part is for people who don't want to upgrade their Engine management and fuel systems more than they need to bolt a simple Turbo kit.
Old Mar 25, 2003 | 12:41 PM
exactvox's Avatar
Is this kit brand new or used?
Thanks,
Jay
Old Mar 25, 2003 | 12:42 PM
bluesaint's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (exactvox)
they are new.
Old Mar 25, 2003 | 01:19 PM
DXturbo's Avatar
this a great deal! i picked mine up new for 2400. bump for you! DOPE *** KIT
Old Mar 25, 2003 | 01:42 PM
CWESTINAP1's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (Wanksta37)
can u get the apex b16a turbo kit?
Old Mar 25, 2003 | 02:03 PM
bluesaint's Avatar
Thanks! up up.
Old Mar 25, 2003 | 02:47 PM
bluesaint's Avatar
i will check on the b16a kit.
Old Mar 25, 2003 | 04:27 PM
Tuan's Avatar
can you run A/C with this kit?
Old Mar 25, 2003 | 04:55 PM
Broken Gearbox's Avatar
Shouldnt it fit all D16s?? cause i know the Greddy Kit can be put on all the d16s with some modification
Old Mar 25, 2003 | 05:12 PM
bluesaint's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (x lP lL i c i t)
I'm just telling you what Apexi says. It says 92-95 Ex- SI
Old Mar 25, 2003 | 05:25 PM
LL95's Avatar
What forms of payment do you except?
Lee
Old Mar 25, 2003 | 05:29 PM
bluesaint's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (LL95)
you have PM
Old Mar 25, 2003 | 05:51 PM
mantic6t9's Avatar
That's pretty cheap. Can anyone vouch for you?
Old Mar 25, 2003 | 06:42 PM
bluesaint's Avatar
Default Re: I have 4 Apex Turbo kits for sell. $1300 92-95 EGs. (mantic6t9)
b18c1_powered_si (brian wong)
Chrisj
there are other users who bought from me in the past. you can search under archive once it's working again.
Also, i'll be directing you to a reputable shop for this purchase and pickup and ship from. I'm basically just spreading the word since it's a limited time deal and could be gone before this week ends. The $ won't be going to me.
Old Mar 27, 2016 | 01:03 AM
mohd noor's Avatar
Icon4 AX53B60-P18 ball-bearing turbo
i got apexi b series turbo kit....can it be repair or rebuild???im in trouble pls someone tell me...it make me dizzy......sshit happen...when install it make grinding sound when revving....
Old Mar 27, 2016 | 03:19 AM
dylspil's Avatar
Default Re: AX53B60-P18 ball-bearing turbo
bumping a 13 year old thread
make a new thread for this. i'm sure people will be much more willing to help you if you give proper details about what's happening
kloscivicsi
Nov 28, 2012 09:23 AM
fenixphreak
Mar 21, 2004 12:26 PM
JRSCCivic98
Jun 4, 2002 06:10 AM
