Underdrive pulley and fuel regulator
Old Mar 25, 2003 | 12:13 PM
accord ex's Avatar
Default Underdrive pulley and fuel regulator
Should i buy and underdrive pulley and a fuel regulator to increase the horsepower of a 95 accord ex? And what will the gain be if any ? Thanks.
Old Mar 25, 2003 | 12:19 PM
3700 Vtec's Avatar
Default Re: Underdrive pulley and fuel regulator (accord ex)
There's plenty of other mods I would do before that. What do you already have done?
Most people will not need a FPR.
I would suggest staying away from using a lightened crank pulley becuase of the <U>possible</U> damage that can be caused. I had one and the revs seemed to jump in an irregular fasion, most likely due to a problem with the belts. The gains off it are minimal an a N/A car.
[Modified by 3700 Vtec, 4:30 PM 3/25/2003]
Old Mar 25, 2003 | 12:37 PM
NathanMorris's Avatar
Default Re: Underdrive pulley and fuel regulator (3700 Vtec)
I saw a dyno for AEM's underdrives (which cause no problems), 3-4hp if I recall correctly.... wasn't a bad number for what they are...on a 5th gen too. Anyhow, an FPR is only needed if your boosting or spraying.
Old Mar 25, 2003 | 12:42 PM
3700 Vtec's Avatar
Default Re: Underdrive pulley and fuel regulator (92Lx)
AEM's just acessory pulleys (Alt. and AC.). Underdrive involves the crank pulley.
Even with some N20 kits you won't need a FPR.
Old Mar 25, 2003 | 12:59 PM
accord ex's Avatar
I have a cold air intake, obx headers, and a cat back exhuast
Old Mar 25, 2003 | 01:05 PM
3700 Vtec's Avatar
V-AFC or hondata would be good. Cam gear would also be nice, that's what I'm doing next. You need dyno time with those mods. Also, high flow cat or test pipe is simple.
acmoc
11
Apr 29, 2009 11:59 AM
tag0617
Apr 12, 2009 06:13 PM
See Are X
Jul 1, 2003 07:47 AM
brawl
Mar 13, 2003 06:39 PM
son-8
Sep 4, 2002 06:33 PM
