H23 head on a h22 block...is this gay?
Old Mar 25, 2003 | 10:53 AM
ludesleep's Avatar
Default H23 head on a h22 block...is this gay?
Guys i can find a h23 block(sleeved) anywhere but i have come across a couple sleeved h22a1....i have a h23 head to bolt to it...should i?
Old Mar 25, 2003 | 10:55 AM
Frankie324's Avatar
Default Re: H23 head on a h22 block...is this gay? (ludesleep)
very gay
Old Mar 25, 2003 | 11:15 AM
satan_srv's Avatar
Default Re: H23 head on a h22 block...is this gay? (Frankie324)
very gay
You obviously don't know what you're talking about.
There is nothing wrong with this idea cause you're boosting so you don't need VTEC, however, realize that the compression ratio of the H22a pistons in the H22a block will go up becuase the H23 combustion chamber is smaller. around .5 points
unless you are planning on using your H23 pistons, in which case the CR will drop a little because of the smaller crank...
and your motor wil rev better.
Old Mar 25, 2003 | 11:23 AM
ludesleep's Avatar
Default Re: H23 head on a h22 block...is this gay? (satan_srv)
alright so yeah im gonna prob go h22a1 block...h23 crower rods(stock size) Je 9.0:1 ..........the ONLY thing im worried about...is my moroso oil pan? Im not familiar with h22 and i dont wanna have to part with this thing will it bolt up?
Old Mar 25, 2003 | 01:42 PM
Lousy Beans's Avatar
Should bolt up with no problem
Old Mar 25, 2003 | 01:43 PM
2point6's Avatar
Default Re: H23 head on a h22 block...is this gay? (Seth Davis)
the blocks are almost Identicle castings.
Old Mar 25, 2003 | 01:51 PM
satan_srv's Avatar
no no no this is the part you're not getting. You have to match H23 crank with H23 rods, so don't put h23 rods on an h22a crank or your pistons won't make the deck height.
Other than that you will need the H23 tensioner, timing gear and H23 block pieces off your toasted block.
Are you using JE 9:1 H23 pistons? or H22 pistons
Old Mar 25, 2003 | 02:04 PM
ludesleep's Avatar
o i know what all to use, im just worried about the oil pan is it the same?
yeah im useing je pistons
[Modified by ludesleep, 11:05 PM 3/25/2003]
Old Mar 27, 2003 | 07:02 AM
satan_srv's Avatar
the oil pan is the same.
H22a pistons with an H23 head means the CR goes up, or are they H23 pistons??
Old Mar 27, 2003 | 07:10 AM
ludesleep's Avatar
they are h23, ive never touched or owned any kind of h22 in my life. This is the first time I will only because i cant find a sleeved block.
Old Mar 27, 2003 | 07:15 AM
satan_srv's Avatar
Well in that case if you are using H23 crank/rods/pistons it is just like an H23 block. Slap on an h23 head and you are rolling....I forget you may have to plug something for VTEC oiling but that's it.
Old Mar 27, 2003 | 08:35 AM
Finest's Avatar
And what's preventing you from sleeving your old block? Or getting a spare H23 block and sending it out to be sleeved? They're a dime a dozen, practically.
Old Mar 27, 2003 | 09:20 AM
satan_srv's Avatar
Default Re: H23 head on a h22 block...is this gay? (98CTRCoupe)
He wants something built now ready to go...so the market for built H23 blocks is pretty slim
Old Mar 27, 2003 | 09:52 AM
Flh22chic's Avatar
If you have a couple H22 sleved short blocks, let me know. i will buy one. I am looking for one right now.
xtjentx
May 17, 2007 05:15 AM
dk4ever
Jan 1, 2007 09:09 AM
Nikoli
May 4, 2004 06:50 AM
GOLDBERG
May 27, 2003 09:20 AM
littleredhatch
Dec 5, 2002 05:49 AM
