Suspension and engine bushes: No search available...
Who has uprated all their suspension bushes in their R? My car is now on 43k miles and i has been driven HARD. I want to fit all new bushes and have been assured that the best kits come from america. I am also interested in changing the engine and gearbox bushes. Who has done this and what difference did it make on street/track car. I would assume it would tighten up my car nicely.
What low priced little tricks does anyone have for the R as well such as roll bars and well i dont know what else without changing the dampers (dont have the money right now) as I want everything to be done and ready for when ther coilovers go on...
Also what about camber adjustment etc
Phew... cheers guys.
[Modified by Year One Racing, 6:17 PM 3/25/2003]
If you have some money to spend.
http://www.kingmotorsports.com/categ...ory=Suspension
If you want to try a cheap method.
http://www.raktron.com/misc/mt.htm
I have the Energy Suspension "Motor Mount Inserts-(3 Torque Mount Positions)" on my car and think that upgrade is suitable for my use.
I also have the "Manual Transmission Shifter Stanbilizer Bushing Set" and enjoy that.
http://www.energysuspension.com/acura.html
or install a larger rear sway bar (23, 26, 28)
Also try adjusting your toe settings closer to zero and see how you like the feel.
I have the ES Motor mounts and all the bushes that will fit the ITR going on while the engine is being built.
I already have the B&M shifter bushings and they are well worth the price, the B&M is solid aluminium with an offset hole so you can adjust the position of the levert back and forth.
[Modified by RICHJ, 8:11 PM 3/25/2003]
not yet but hoping they will go on while the engine is out, I will report back with any that don't fit the UK model (if any), I can then make up a list of part numbers of what fits and the extra Powerflex ones that would be needed to complete the job (hopefully very few as their prices are a ripoff) I have the Powerflex diagram and have painted in the ones I have bought but will check that all fit before advising others which are OK)
[Modified by RICHJ, 7:17 PM 3/26/2003]
jasonb
Suspension & Brakes
Dec 26, 2008 01:57 PM
