tial wastegate gasket blown?
Does anyone know what type of sound it would make if it was leaking? because I didnt notice the sound till last night, it only occurs when I apply the gas not that loud but enough to hear it pretty good, at steady cruise speed there is no sound only when there is a load on the engine. It sounds like a tpst--tpst--tpst--tpst kinda of hard type it. At first I though it was my valves but if I rev at idle there is no sound either, engine idles fine runs fine also, I did a compression check and it was good all across the board, it builds boost fine also but I thought if there was a leak it would take longer to build boost unless the leak is small. Just wondering if anyone had it blow on them before and what type of sound it made, just to make sure.
well good thing i installed mine knowing taht most people on honda-tech say they blow and out to not even bother and use no gasket, i'll sell you 2 gaskets for $12 shipped, one is cut in half to fit around the valve seat ring but still usable, both unused, but just try and use no gasket, the barbon build up would probably seal it i would think
dont run a gasket guys use just a small beed of hi-temp silicone u guys will never have that probilem again
lol not even i got high temp **** that goes up to 1200 degrees **** my egt gets up to 1400 sometimes and no probilems yet and fire rings suck i use to blow them out to no gasket or silecone is the way to go but i would use silecone **** works perfect
Tial wg gaskets blow...my brothers blew in like a day on his 240sx. We just make one out of a real thin sheet of plyable aluminum.....been working for about 1 and 1/2 months now.
I had no problems running without gasket if you don't mind a little carbon buildup from pinhole leaks.
Firering gasket works great in my opinion. If you put it on right and torque down properly, they should not blow. ran mine at 16psi without any issues
Would the gasket being blown affect boost creep in the slightest? just curious because all of the sudden, im starting to creap a lil bit..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">try using the deltagate firering</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIXTYdashONE »</TD></TR><TR><TD CLASS="quote">Would the gasket being blown affect boost creep in the slightest? just curious because all of the sudden, im starting to creap a lil bit..</TD></TR></TABLE>
? ttt
? ttt
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
I blew my tial gasket as well, I tried running without any gasket, but the Maxrev manfiold isn't perfectly flat, so I was still leaking. I ordered a Firering from RoadRace, got it in on Thursday. Works well with no leaks now.
Im having the same problem. My gasket blew and I did start to have boost creep problems. Im not sure if that is the reason its creeping or not, thats the only thing I can think of that could be making it do that though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDelSol »</TD></TR><TR><TD CLASS="quote">what turbo manifold do u have ..if its drag i no how to fix the gasket problem..let me no </TD></TR></TABLE> how do you fix it??? THats what i got and im blowing my gaskets .. but before when no gasket was being used was leaking. bc could see the blackness on the head and wg.
The reason that this question arises so much is because the seating area between the maifold and the wastegate is not flush. and little tiny crevice that this hot gas can creep through will burn a hole. Either the casting is crappy or the flange that was welded on got warped in fabrication.
