Need specs on the flywheel.
As the title states, I need specs on the flywheel in my F22B1 transmission. The Helms only lists the runout specs, I need to know the service limit minimum thickness and the finish requirement. Thanks
http://www.advanceclutchtechnology.com has flywheel machining specs listed.
their site has changed, but i guess they got rid of it. it used to be in a FAQ section. i would call the honda service department or stop by. they are usually pretty helpful.
Well they have a FAQ section but all it says is that a flywheel must be resurfaced on a flywheel-grinder to ensure proper friction between the clutch and flywheel.
As for asking Honda, I guess it wouldn't hurt since I'm going there today to pickup some new bolt so I can reinstall my front rear beam (subframe). Is there anything specific I should ask for other than the minimum thickness, surface finish requirement, and run-out?
I need some specs for clutch install.. Flywheel torque specs, PP torque specs, and flywheel stepping
DamonBoost
Mar 1, 2002 10:38 AM
