Removing front anti roll bar without dropping linkage?
Old Mar 24, 2003 | 09:14 PM
Rywire's Avatar
Default Removing front anti roll bar without dropping linkage?
Is this possible? I dont have the tool handy to remove the linkage pin, and want to install the rest of my polyurethane kit. Thanks, Ryan
Old Mar 25, 2003 | 04:36 AM
keithv's Avatar
Default Re: Removing front anti roll bar without dropping linkage? (droppedcrxsi)
an exhaust bolt works great for punching out the "bitch pin".
Old Mar 25, 2003 | 08:12 AM
Aron Parsons's Avatar
Yes, it's quite possible. I've done it numerous times. Just jimmy it around. You must have the car high off the ground so you have room to swivel the bar around.
Old Mar 25, 2003 | 08:25 PM
Rywire's Avatar
Default Re: Removing front anti roll bar without dropping linkage? (Aron Parsons)
OK, thanks. Ryan
Old Mar 26, 2003 | 03:59 AM
zCivic's Avatar
Yeah you can just wiggle it around either thru the driverside or pass side wheel well. I did it without even taking the tires off Just jacked up 1 side and was good to go.
Dchase
Jun 4, 2009 05:41 AM
krysmagnetic83
Suspension & Brakes
May 20, 2005 08:23 AM
Weston
Jan 20, 2003 06:52 AM
PhoBichNga
Jun 21, 2002 11:37 PM
rltrock
Oct 9, 2001 02:10 PM
