ST Rear Away Bar + MX Exhaust = Won't Fit?
I'm having trouble installing my ST rear sway bars. Already got the lower control arms switched, but there seems to be a clearance issue... anyone else have this problem, and how to get around it? Thinking I might have to move the muffler...
From: A place where stupidity runs rampant aka NorCal
I have this exact setup with 0 problems except that i had to wrap the sway with some e-tape to thwart the occasional rattle. Suspension is Koni Yellows, kg/mm sr21 supersport springs, ST rear sway bar on full soft.
I guess this would be the only pic i have to see that im not lying
You can see the Greddy MX obviously, you can see the koni yellow peeking out from the right inside of the tire, and you can see the lower bolt of the ST swar bar (the silver bolt to the right of the exhaust)
-Todd
[Modified by Count Blah, 8:37 AM 3/25/2003]
-Todd
djdownfawl
Honda Civic (2001 - 2005)
39
Dec 1, 2008 07:34 PM
synergy10
Aug 17, 2005 08:46 AM
rhettster
12
Feb 3, 2003 10:23 PM
moridin2004
Jan 10, 2003 01:44 PM
