Help: Have to clutch down several times to get in gear.
Old Mar 24, 2003 | 02:49 PM
canadaitr's Avatar
Default Help: Have to clutch down several times to get in gear.
Hello all,
I am new to the Type-r world and my car is giving me a bit of a problem. Sometimes when i come to a dead stop I can't get into gear (any gear); I have to press the clutch several times and only then can i get into gear (with hesitation). Also, if I turn the car off and try to shift into gear, there are no problems at all. Could you all please throw some light on this.
Cheers,
canadaitr
Old Mar 24, 2003 | 02:50 PM
sgT's Avatar
sgT
Default Re: Help: Have to clutch down several times to get in gear. (canadaitr)
flush the clutch fluid
otherwise you may be in need of a new clutch.
Old Mar 24, 2003 | 02:53 PM
RTW DC2R's Avatar
Default Re: Help: Have to clutch down several times to get in gear. (sgT)
how high does the clutch engage/disengage? do you have to press it all the way in to shift or can you press it halfway and shift?
Old Mar 24, 2003 | 03:44 PM
Big Phat R's Avatar
Hello all,
Cheers,
canadaitr
Getting into 1st is a perennial problem for a lot of people - usually will go "in" if you let the car roll forward or backward a bit (with the clutch pedal depressed).
Otherwise what SGT said.
Old Mar 24, 2003 | 03:48 PM
canadaitr's Avatar
Default Re: Help: Have to clutch down several times to get in gear. (RTW DC2)
When it wants to go in, I can get it into gear even with the clutch only halfway down.
Old Mar 24, 2003 | 07:11 PM
Phoenix_ITR's Avatar
how long has it been since you changed the transmission fluid??
-tony
Old Mar 24, 2003 | 07:17 PM
SamB's Avatar
New User
Agreed. Had the same problem in our Civic, that was the only symptom - no slip, not engaging funny. New clutch made it like new again.
John 07
Sep 11, 2012 07:18 PM
silent-chris
Honda S2000
Sep 17, 2006 09:00 PM
ablack934doorcivic
Nov 1, 2005 02:02 PM
eMbrace
May 14, 2005 07:47 AM
Chief Brody
Aug 4, 2004 09:28 PM
