95 GSR counter shaft into a 92 GSR Tranny
yes it can be done as long as the the new countershaft has the same amount of teeth as the old countershaft. if the teeth dont match up then you can use the new countershft as long as you use the ring gear(diff. gear) out of the 92 tranny also!
DA is best
Mar 12, 2009 07:13 AM
