Installing Skunk2 Stage 2 Camshafts
Old Mar 24, 2003 | 10:03 AM
7rrivera7's Avatar
Default Installing Skunk2 Stage 2 Camshafts
I just got a set of Skunk2 Stage 2 cams and my mechanic says due to the specs, it'll take him a full day to 'degree' the engine and that I have to pull it out (the engine) and take it to him.
Does this make sense timewise? What is 'degreeing'?
Old Mar 24, 2003 | 10:28 AM
REDBARON's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (7rrivera7)
I don't know what the hell your machanic is talking about. Taking out the engine to put in cams is new to me. Also I'm not sure on what "degree" is.
Old Mar 24, 2003 | 10:47 AM
AllmotorJunkie's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (REDBARON)
I don't think it should take a day to install cams. Me and my friend did it in about 4 hours and we were farting around too. Consult another mechanic...
Peace
Old Mar 24, 2003 | 10:56 AM
m0t0rhead's Avatar
Find a new mechanic. This guy is nuts.
Old Mar 24, 2003 | 11:06 AM
raene's Avatar
For domestic cams you have to install the cam in the middle of the block, meaning tilting the block out of the engine bay... you can get away without doing it on some of them. That's probably what your mechanic is talking about. Sounds like he's stuck in the '60s
Old Mar 24, 2003 | 02:58 PM
rustyeleio's Avatar
Take a look at the Web Camshaft page for a description of why you should degree a new camshaft. < http://www.webcamshafts.com/degreeing.html > I have never done this but I just read it out of curiosity.
Old Mar 24, 2003 | 03:02 PM
All_Lag's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (rustyeleio)
Find another Mechanic either he is stupid and dosent know your engine is an overhead cam, or he thinks your stupid and just wants to overcharge you. It took me 2 hours by myself putting my crower cam in my first time.
Old Mar 24, 2003 | 11:56 PM
B00ST2nR's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (SlowSOHC)
Screw him. What a dumbass.
It will take an Import Mechanic 2 hours to install cams and a Valve adjustment afterwards.
Old Mar 25, 2003 | 04:40 AM
m0t0rhead's Avatar
Not to hijack this thread... but you installed a crower cam ? What motor ? How do you like it ? Any good gains ?
[Modified by Escobar, 8:40 AM 3/25/2003]
Old Mar 25, 2003 | 06:27 AM
Robb's Avatar
Degreeing the cams is very important for peak performance. And it takes a looong time to do correctly.
Old Mar 29, 2003 | 11:10 AM
7rrivera7's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (Robb)
Ok, but do you have to have the engine outside to do this?
Old Mar 29, 2003 | 11:49 AM
Rob Dizzle's Avatar
this is getting really retarded really fast.
go to http://www.c-speedracing.com for cam install procedure
install for cams:
1. take off valve cover
2. take off cam plates
3. using an extension of I think a 14mm socket. align crank to TDC
4. when you put the cams in, the cams will only fit in correctly (not 180*) off when you push them into the distributor.
5. intall all the parts
of course cam install is more detailed than this.
but there is no nead to degree the cams. they will be properly setup (at 0*) when you put them into the distbutor. you will know just from looking at them in relation to how the cams sits in the head where the rockers are. there will be gaps of space between the valve rockers are the lobes of the cam.
take your car to someone who has done import car (hopefuly b-series) engines before.
taking your engine out is not needed. i would walk away the minute i heard that you need to take an engine out to install cams.
there is no common sense in this thread
[Modified by Bob-DC2, 12:50 PM 3/29/2003]
Old Mar 29, 2003 | 02:19 PM
TRENDSETTLER's Avatar
Default Re: Installing Skunk2 Stage 2 Camshafts (Bob-DC2)
ditch that guy....no need to remove the motor for a cam install
panda_eh2
May 1, 2008 08:16 AM
Liquid Ice NF
Aug 15, 2005 07:26 PM
pIMp NO
Mar 26, 2003 06:36 PM
