self installing koni's and H&R, help?
Old Mar 24, 2003 | 06:21 AM
One Slow Lude's Avatar
Default self installing koni's and H&R, help?
Is is pretty easy to install new koni's and H&R springs on an sh lude if you are mechanically inclined? or does the sh factor throw the plan off? i can have it alligned right after, but im just worried about the atts BS..... thanks
Old Mar 24, 2003 | 09:20 AM
laughinxxx's Avatar
New User
Default Re: self installing koni's and H&R, help? (POSlude97)
It shouldn't be a problem. I did mine without a Helm's on my 4G.
Old Mar 24, 2003 | 10:07 AM
Default Re: self installing koni's and H&R, help? (laughinxxx)
So you dont think I'll mess up the ATTS then?
Also, to people who have had their's installed by a shop, how much did you pay for instalation, just out of curiousity for my other options....???
Old Mar 24, 2003 | 01:25 PM
laughinxxx's Avatar
New User
I'm no Type SH expert, but I don't see how you could mess up the ATTS with a spring and shock install.
Old Mar 24, 2003 | 02:21 PM
Lousy Beans's Avatar
You won't have a problem...Straight forward stuff
Old Mar 26, 2003 | 08:27 PM
soooo. anyone live new newburgh NY and want to help a fellow luder put in springs and shocks?? (thats knows what they are doing). Also, is $150 for instalation of springs, shocks, header, exhaust, without an alignment worth it??
Old Mar 26, 2003 | 08:34 PM
laughinxxx's Avatar
New User
I wouldn't let anybody touch my car for any amount of money unless I knew exactly what they were doing and could correct them if they fucked it up.
Old Mar 26, 2003 | 08:40 PM
it a friend of mine, the real problem is i dont want to drive out to his shop. "the drop shop" I believe jon knows what he is doing, he has installed my header and exhaust before, but honda made me remove them for warranty work , so i need them in again. The only thing is i dont know if the driving time and money is worth the easier instalation factor as opposed to the the save money but have a harder time since i dont have a lift.....
Old Mar 26, 2003 | 09:27 PM
SleekBlkPrelude's Avatar
u don't need a lift... all u need is jackstands... a pneumatic jack is helpful when u wanna push up the control arm to make space to take the stock shocks out...
btw: taking the front right stock suspension is a BITCH! u gotta wiggle it and move it slide it and shake it out.. there is this little nub that almost makes u want to cry...
Old Mar 27, 2003 | 05:20 AM
tom_collins's Avatar
I just replaced all my stock suspension with a tein ss system, f/r upper strut bars, and a rear sway bar and end links. It really wasn't too much of a problem. Took time and a little patience with stuff, but other than that it wasn't too bad. You'll want a good set of tools though, and you might need to get a couple specialized tools as well. A real good place to find some instructions is on the NTPOG site.. http://www.ntpog.org go under mods and then look at the fifth gen replacing springs section. On the SH you'll need a ball joint thingamabobber for the fronts but I think most auto parts places should have it. In total on my base I ended up buying a set of spring compressors, a pittman arm puller, a set of metric allen wrenches, and a couple regular wrenches. Was a good time. I could have spent the money and had someone else install it, but instead I spend less money, gain the tools, and the knowledge. Good deal for me.
Old Mar 27, 2003 | 05:56 AM
Gennady's Avatar
New User
Default Re: self installing koni's and H&R, help? (tom_collins)
http://www.accordinglydone.com/tech.php?ID=71
Old Mar 27, 2003 | 08:48 AM
Default Re: self installing koni's and H&R, help? (SleekBlkPrelude)
Thanks for the info. So how much do you have to cut the bump stops?(if at all)?
Old Mar 27, 2003 | 09:24 AM
laughinxxx's Avatar
New User
It will tell you in the instructions in the box that the springs come in.
jimmy o.
Dec 16, 2009 10:30 PM
sleevedgsr
Dec 16, 2004 09:16 PM
Chief Brody
Oct 8, 2003 07:38 AM
EVIL Hx Coupe
Sep 3, 2002 12:30 PM
Razor
Dec 18, 2001 07:06 AM
