brake booster question.
Old Mar 23, 2003 | 09:43 PM
spun Vtec's Avatar
Default brake booster question.
i have an 89 civic si and i recently upgraded my brake system with the following:
91 crx si rear trailing arm
99 si rear caliper's and rotor's
front 10.5' 99 si caliper's and rotor's and knuckles
91 crx si mastercill
91 crx siperportioning valve
nuspeed stainless lines
i dodnt touch the brake booster is the 89 si any diff from the 90-91 booster? and if so should i get an integra booster because of my integra sized brakes on all 4 corner's?
thanks just didnt think about the booster till today.
i never hear people talk about doing the upgrade so i hope there the same.
-larry
Old Mar 23, 2003 | 09:59 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: brake booster question. (4gsicivichatch)
you should get the integra booster. it'll match your integra altezzas on your hatch.
Old Mar 24, 2003 | 06:04 AM
REDBARON's Avatar
4gsicivichatch, I don't think you'll need it. I would try the current setup first, and see how it handles. But I don't see you having any problem with that setup.
I am currently using the CRX HF MC, and BB with the Teg front brakes with no problem.
Old Mar 24, 2003 | 08:10 AM
4drEF's Avatar
Keyboard Humorist
You don't need the booster, but you should look into taking out that Si master cylinder and swapping out for a 4 door EX unit. Master cylinders from the DX/LX/... were all 13/16", the Si's with the rear disc brakes were supposedly 7/8", and the EX had a 15/16" because it has the large front brakes.
The EX MC will bolt directly to your booster (and is the same part number from honda as far as I know).
Old Mar 24, 2003 | 08:20 AM
Adam F's Avatar
Default Re: brake booster question. (4drEF)
you shouldn't need the booster, all that does is assist you through vaccum.
ki11r0y1086
Suspension & Brakes
Nov 22, 2016 08:26 AM
delinquent
Sep 12, 2009 04:18 AM
Davanca
11
Mar 15, 2004 12:27 PM
polycrx
Feb 15, 2003 03:51 PM
