ZC wiring questions..
Old Mar 23, 2003 | 04:27 PM
drjondurst's Avatar
Default ZC wiring questions..
The two plugs circled in the red are exactly the same.. so they'll plug into both sensors or whatever those are. Do I have em in the right ones?
I've plugged everything up and came up with this plug that has no where to go. I see where it goes on the Si engine (I could go take a pic if that'd help) but I dont see where it should go on the ZC.
Close-up of the plug without a home. Look behind the plug at the thing circled in yellow.. do I have that hooked up right? First of all, what is it? What'll happen if I have the wires switched.. I just shoved em in in no particular order.
Thx for the help.
Old Mar 23, 2003 | 05:16 PM
G-reX's Avatar
Default Re: ZC wiring questions.. (drjondurst)
Well the first 2 plugs are right but I have never seen that other one b4. And as for the one circled in yellow that is your coolent fan switch, it doesn't matter what way thats hooked up. If thats any help for ya.
[Modified by G-reX, 2:19 AM 3/24/2003]
Old Mar 23, 2003 | 05:22 PM
drjondurst's Avatar
Default Re: ZC wiring questions.. (G-reX)
Awesome, which fan is the coolant fan?
Now I just need to know what that extra plug goes to/does.
Old Mar 23, 2003 | 05:45 PM
xjoe's Avatar
that extra plug (one circled in green) doesnt get plugged into anything on the zc .. i forget exactly what it's for on the si engine, but you dont hook it up on a zc. you can either cut it off or let it hang, i chose to let it hang. HTH
Old Mar 23, 2003 | 05:47 PM
drjondurst's Avatar
Default Re: ZC wiring questions.. (xjoe)
Thanks, I thought so but wasnt sure. Im just gonna tape it up and out of the way.. never know, I might need it some day.
Old Mar 23, 2003 | 05:51 PM
elpermgrande's Avatar
I have the same plug with no place to go on the back of my Si engine.I have an 88 engine and the engine harness is a 1990 and I think the earlier engines,88-89, didn't have that thing but my 90 harness it was plugged into a vacuum line of some sort but it is not necessary for it to be plugged in if it doesn't have the correct piece.Oh and drjondurst, what are you going to do with your old Si engine?If you want to get rid of it let me know since I am in Oklahoma also.
Old Mar 23, 2003 | 06:05 PM
drjondurst's Avatar
Default Re: ZC wiring questions.. (elpermgrande)
Im not really sure, I have a friend that wants it but doesnt have the money and probably never will. Where in OK are you?
chase7687
Oct 4, 2009 07:30 AM
AudioXtremes
Apr 11, 2006 01:26 AM
silver hatch
May 31, 2005 08:51 PM
ZC_powered_4dr.
Oct 28, 2002 07:36 PM
ScottEK
Sep 26, 2002 11:50 AM
