need help wtih closed deck and open deck..
Old Mar 23, 2003 | 03:12 PM
sslude's Avatar
Default need help wtih closed deck and open deck..
i searched but i didnt find the answers i needed. when it is an open deck, coolant runs throught hte space right? but what happens when it is a closed deck. where does coolant run through? also, where does the water pump pump water to? where does it get water from? if i could get pictures, that would be a great help to explain this to me. TIA
Old Mar 24, 2003 | 03:45 PM
sslude's Avatar
Default Re: need help wtih closed deck and open deck.. (sslude)
anyone?
Old Mar 24, 2003 | 03:58 PM
TimoneX's Avatar
New User
A closed deck has holes that run the length of the sleeves allowing coolant to pass through them and cool the cylinders. I prefer to retain the open deck because the closed deck generally doesn't allow quite as large a bore due to it's design and restricts the flow of coolant somewhat. I found some pics of a GE sleeved B18a here:
https://honda-tech.com/zerothread?id=388267
Didn't see any pix of a Darton closed deck block readily available though I've seen them on here previously.
Old Mar 24, 2003 | 04:03 PM
sslude's Avatar
Default Re: need help wtih closed deck and open deck.. (TimoneX)
and what about the water pump question?
Old Mar 24, 2003 | 07:50 PM
sslude's Avatar
cmon, someone has to know
Old Mar 25, 2003 | 04:47 AM
TimoneX's Avatar
New User
Most people probably don't understand the question, I'm not sure I do either. The water pumps water through the water channel on the back of the motor(B series) it travels through the heater, water jackets, & radiator.
accord1986
Jan 27, 2013 03:01 AM
dleccord
Jan 11, 2010 06:59 PM
totsie7944
Oct 31, 2008 02:44 PM
Obama
Jun 20, 2007 07:10 PM
raene
Mar 1, 2003 05:06 PM
