Headders... what one to buy ?
Old Jun 14, 2001 | 03:02 PM
K-Drum's Avatar
Default Headders... what one to buy ?
well.. i'm an other Purehonda migrator...
anyway i was replacing my valve cover gasket today when i desided to remove the heat shield on the stock header... to find it's cracked... well I need a new headder... what one should I buy... I like DC but it's a little pricy for me since I am considering a B16a1 swap.
I'm looking for a good cheap header... any ideas... also a url to where i can buy it would be great.
K-Drum
1990 CRX SI
Old Jun 14, 2001 | 08:40 PM
BIG RICH's Avatar
Default Re: Headders... what one to buy ? (K-Drum)
Well, I think if your going to get a b16a, you shouldn't waste the money on a header for your current engine. just patch it up. But if you really want one. Chikara makes headers, I've heard there pretty good. they cost around $120 from summit racing. Airmass makes good ones too, they cost about $275.
Old Jun 14, 2001 | 09:01 PM
90civicrider's Avatar
Default Re: Headders... what one to buy ? (BIG RICH)
wait till you do the swap to get a header..
i like Jackson Racing! thats what i plan on getting but otherwise
i would suggest DC Sports, Jackson Racing, Neuspeed.
those are all good ones
Old Jun 15, 2001 | 01:55 AM
oOxsboostOo's Avatar
New User
Default Re: Headders... what one to buy ? (90civicrider)
dont waste your money....... if you plan on swapping the motor "soon" then it would be a waste of time and money installing a new header.
I recommend calling some local junkyards, you should easily find an old exhaust manifold for less than $50.00. Just remember to hit all the old nuts/bolts with WD40 before cracking them loose on the block, and you will need a new gasket between the lower y-pipe and the catalytic converter if you replace the whole thing. Copper gasket sealer should help prevent any exhaust leaks. Remember to tighten all nuts/bolts to OEM honda specs.
EGman18
May 3, 2009 08:08 AM
type-GGSR
Dec 23, 2007 09:05 PM
94IntegraLs04
Mar 30, 2006 03:50 PM
ROCAFELLA2049
16
Apr 10, 2005 11:38 AM
crxdriver89
13
Mar 31, 2004 01:10 PM
