accord clutch install?
I have a friend with a 1991 (i believe) Accord that needs a new clutch. I have changed the clutch in my del sol, crx, and hatch before. i was assuming that the swap would be the same as the civic platform.
is it? is there anything i should know that is different about an Accord clutch than a civics?
thanks guys.
thanks guys.
Civic clutches are much easier than Accord clutches. 91-93 Accord clutches use cable actuated shift mechanism, and as stated above, it has much less "wiggle room". Make sure that you use a good clutch alignment tool, or you will have a heck of a time getting the trans. back in.
well got it all done and back together, it want to hard actually. the cable shiftign is much easier to deal with than the civic shift linkage. but there is so muc crap in the way in the engine bay. oh well took me about 8 hours to do.
