Puddle of water inside my hatch today.
My 91 civic si has been sitting for about 2 months, at times it had snow built up on it. I went out to it today to clean it up and there was a puddle of water behind the drivers seat. Where could this be coming from?? Leaking from sunroof?? Thanks.
beats me, but after heavy rain when i get in my hatch water pours all over my left foot when i am clutching. the drain channel doesnt seem clogged...
I have a slow leak coming from the right rear pillar of the hatch (where the seatbelt is bolted to).
[Modified by Mista B-one-seven, 3:41 PM 3/23/2003]
on my crx i have several leaks.. problems that just appeared recently...
the rear sunroof drain tubes usually become clogged
tail light seals leak.. so i siliconed those and drilled tiny holes into the bottoms of the tail lights
the front leaks..
1. if u've ever had your windshield replaced.. like mine is leaking i have to get it resealed
2. check the hoodcable rubber grommet in the body
3. sunroof drains
4. the roof rails on top of the car could be cracked..
5. seals around the sunroof could be leaking too
hope that helps..
the front leaks..
3. sunroof drains
hope that helps..
crxforum
Oct 30, 2006 01:15 PM
