Will I Need A Camber Kit For My Prokit/Koni Yellow Setup?
Old Jun 14, 2001 | 01:29 PM
George H's Avatar
Default Will I Need A Camber Kit For My Prokit/Koni Yellow Setup?
Now that I decided to get the prokits to go with my koni yellows, will I still need a camber kit. I plan to leave the konis on the middle pearch front and back. Also, do I need to get the front and back ones?
The reason i'm asking is that originally I had the sportlines and ordered Ingalls Extreme camber kit for the front and rear, and now I need to know whether to exchange them for the non-extremes because of the prokits less agressive drop.
One more thing, should I get the ingalls or should I go with the Eibach camber kit?
Thanks
Old Jun 14, 2001 | 01:53 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Will I Need A Camber Kit For My Prokit/Koni Yellow Setup? (KANJI)
Kanji - No, you won't need a camber kit. Just get an alignment in the near future and you should be fine. I've had the same set-up for 2 years now with no problems with camber.
Old Jun 14, 2001 | 04:21 PM
George H's Avatar
Default Re: Will I Need A Camber Kit For My Prokit/Koni Yellow Setup? (Gee3)
Thanks for the response gee3. Has anybody else with this setup had the need for a camber kit, and if not, has there been any uneven tire wear. I'd hate to drop $400 on tires and having uneven wear.
ramboPandA
Mar 27, 2014 03:15 PM
Xathine
Suspension & Brakes
38
Oct 15, 2008 09:51 PM
JDR
Suspension & Brakes
Jun 21, 2005 11:30 AM
VTECTIME
Sep 11, 2002 04:04 AM
George H
Jun 29, 2001 10:32 PM
