IAC!!!! !!!!!HELP!!
Old Mar 23, 2003 | 08:04 AM
winman517's Avatar
Default IAC!!!! !!!!!HELP!!
What would happen if i run a b16asir2 motor witha jrsc and i didnt put on the iac on it. the motor's oil is all white now. would running the motor without a iac mess the motor up>
Old Mar 23, 2003 | 08:23 AM
Chiovnidca's Avatar
Default Re: IAC!!!! !!!!!HELP!! (winman517)
Do you have a blown headgasket?
eg6ajk's Avatar
CEL will come on if its disconnected completly from the motor. but if its blocked off with a plate and connected then it simply means that you'll need to hold your foot on the gas until the motor warms up. but once warm it won't be a problem
Jrimel2208
Feb 2, 2017 02:55 PM
