engine codes with a cutout?
Old Mar 22, 2003 | 10:25 PM
comptechgsr's Avatar
Default engine codes with a cutout?
for the engines that specifically go "exhaust manifold to cat. converter to the rest of exhaust",
here is my q.
say i put a cutout in between the cat and the rest of the catback exhaust,
so the chain reads like this
header----cat---cutout----rest of catback piping---muffler-tip/out
if the cutout is opened, so there is an opening right after the cat,
will there be any engine codes?
say specifically for a honda b-series stock etc etc?
or is everything gravy,
as long as the 1 to 2 o2 sensors is filled etc and there is a cat?
if so, technically one could run just the header and cat and have no exhaust and have no Ecu error codes right?
Old Mar 22, 2003 | 10:51 PM
RCautoworks's Avatar
Default Re: engine codes with a cutout? (comptechgsr)
Yeah your will be fine. Even if you put the cut out before the cat you still would be fine. As long as the 02 sensor in the cat don't get messed around with.
Old Mar 23, 2003 | 05:01 AM
altoid's Avatar
its kind of useless to have a cutout after the cat.
Old Mar 23, 2003 | 11:25 AM
Default Re: engine codes with a cutout? (altoid)
useless
say i have an aftermarket header,
connecting to a bigger than stock cat,
and stock catback....
cutout===ultimate catback
cuz there is no catback
nice for a turbo app. ay?
925EKCOUPE
10
Jun 22, 2009 05:18 PM
dip-set
Oct 21, 2003 07:41 PM
Jimmy
Jul 24, 2003 08:20 PM
Vtec-R
Aug 3, 2001 06:14 PM
