how to properly paint wheels?
Old Mar 22, 2003 | 03:54 PM
magic hat #9's Avatar
Default how to properly paint wheels?
i'm receiving a new set of kosei k1 from tirerack on monday. i picked up some plasti-kote car body paint from pep boys today.
i'm wondering, since the wheels are new (no dirt, oil, salt, etc.), can i just clean & spray the wheels (paint then clearcoat) out of the box or should i go more involved? will i need to go all out: remove the factory paint with aircraft stripper, 400grit sand, prime, sand, paint, and clearcoat?
anyone see a reason why car body paint isn't sufficient? i do track the car, but i don't forsee the wheels getting so hot i melt the new paint.
Old Mar 22, 2003 | 04:07 PM
uNF$@#!'s Avatar
Default Re: how to properly paint wheels? (magic hat #9)
no need to strip.
sand wheel, prime, then paint.
Old Mar 22, 2003 | 05:20 PM
Todd00's Avatar
I said I don't want a title!
Default Re: how to properly paint wheels? (io-burn)
no need to strip.
Agreed. Just rough up the oem finish enough to get the paint to stick, clean and then spray several light coats.
The K1's have a clearcoat on them, so you may need to remove most of that, but there is no need to take the finish down to bare metal.
Use something like a scotchbrite pad then follow up with 320 or 400 grit sandpaper to prime.
Old Mar 22, 2003 | 06:15 PM
SoCal ITR's Avatar
no need to strip.
That's what I would do.
Old Mar 23, 2003 | 10:11 AM
PatrickGSR94
Sep 17, 2014 02:40 AM
WhiteGSR95
Apr 8, 2012 01:50 AM
WhiteGSR95
Paint and Body
Apr 7, 2012 07:01 PM
aargh867
May 29, 2003 07:53 AM
91hatchcivic
May 29, 2003 07:19 AM
