How do I know when the flyweel needs to be resurfaced?
Old Mar 22, 2003 | 01:44 PM
Blaze45's Avatar
Brrraaaap!
Default How do I know when the flyweel needs to be resurfaced?
Im doing a B swap into a CRX and so I have the flywheel sittin out.
The question that I have is that does it need to be machined if there are not any large grooves in it?
tia
Blaze
Old Mar 22, 2003 | 01:54 PM
joe_bocc's Avatar
Default Re: How do I know when the flyweel needs to be resurfaced? (Blaze45)
If you are putting a new clutch on then now would be the time.
Old Mar 22, 2003 | 02:34 PM
Kamin's Avatar
Default Re: How do I know when the flyweel needs to be resurfaced? (joe_bocc)
anytime you put a new clutch (or diffrent used clutch) back on a used flywheel, it should be resurfaced.
Old Mar 22, 2003 | 03:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How do I know when the flyweel needs to be resurfaced? (Kamin)
even if it doesnt look like it needs it? how much does it usually cost?
Old Mar 22, 2003 | 03:03 PM
Kamin's Avatar
resurfacing makes the flywheel completley flat and smooth again. even if it "looks ok" it could still be warped from the previous clutch.
Old Mar 22, 2003 | 04:22 PM
Blaze45's Avatar
Brrraaaap!
ah I c thanks
Blaze
Old Mar 22, 2003 | 04:26 PM
KTeller8's Avatar
if you decide to go with annother one
i got a couple of fidanza flywheels left in stock
250 shipped
7-8 lbs
with hardware ready to bolt and go
B_Swapped93
Apr 4, 2013 06:30 PM
Quada
Transmission & Drivetrain
13
Jun 30, 2010 12:15 PM
huntarrr
18
Feb 4, 2006 11:21 PM
Spectrum24x
Jan 23, 2006 06:14 PM
