92 Accord/Oil leak between distributor and engine/With pictures
Old Mar 22, 2003 | 10:43 AM
Davi's Avatar
Default 92 Accord/Oil leak between distributor and engine/With pictures
Here is an over view of the situation.
To the right (in the first image) is the distributor upside down, unbolted from it's home.
Oil is leaking inbetween the distributor and engine.
Should there simply be a gasket inbetween the distributor and the engine to stop the oil leak?
Oil is sitting just inside, is that normal? (please see next image over)
Old Mar 22, 2003 | 01:11 PM
mwkirchner's Avatar
Default Re: 92 Accord/Oil leak between distributor and engine/With pictures (Davi)
If you look closely on the shaft at the bottom of the distributor ... you will see a black o-ring on it. That is your problem. Replace that and your oil problems will disappear.
Old Mar 22, 2003 | 01:18 PM
badassaccord's Avatar
Default Re: 92 Accord/Oil leak between distributor and engine/With pictures (mwkirchner)
What he said is exactly right.
Adam V
Mar 12, 2018 07:38 PM
realred96
Classic Hondas
Sep 25, 2011 06:26 PM
sonson6
Mar 20, 2007 07:56 PM
porsche997dc2
Dec 22, 2003 05:14 PM
