Snapping swaybar Brackets on my 89 SI Hatch, HELP!
Old Mar 22, 2003 | 09:50 AM
Snapshift's Avatar
Default Snapping swaybar Brackets on my 89 SI Hatch, HELP!
As the title states, I have broken two REAR swaybar brackets in the past week. My car is on 15's with H&R sports. Stock front lower SI bar. Rear 22mm Mugen lower tie bar. Does anyone know who constructs beefier setups for the rear lower brackets? Some Names would really help. Thanx in advance.
Old Mar 22, 2003 | 09:57 AM
Adam F's Avatar
Default Re: Snapping swaybar Brackets on my 89 SI Hatch, HELP! (Snapshift)
what are you doing to snap them and what motor do you have ?
Old Mar 22, 2003 | 10:33 AM
HybridFiend's Avatar
Sounds like maybe some damper adjustable struts/shocks would help prevent breaking the mounting brackets. You could also maybe have someone fabricate you some....machine shop....or if you know someone in a College class or something?
Old Mar 22, 2003 | 10:43 AM
89civicdx's Avatar
what kind of bar is in the back?
try the energy suspension D-bracket...very cheap and strong.
[Modified by 89civicdx, 11:45 AM 3/22/2003]
Old Mar 22, 2003 | 10:46 AM
Malachi_'s Avatar
Default Re: Snapping swaybar Brackets on my 89 SI Hatch, HELP! (Proelite103)
autozone
[Modified by chicken_focker, 8:12 PM 3/22/2003]
Old Mar 23, 2003 | 12:44 AM
Snapshift's Avatar
Im throwing corners hard! Very, Very tight hairpins. My engine is a finely tuned D16A6
Old Mar 23, 2003 | 01:05 AM
Snapshift's Avatar
Default Re: Snapping swaybar Brackets on my 89 SI Hatch, HELP! (HybridFiend)
Actually I myself am very capable of machining tougher hard ware but then my chassis will start to breakdown . A couple of my Autocrossing pals say that because of the stress i put on my car i very much need an upper rear bar as well to reduce the flex in the rear lower brackets. That should fix my problem they state Thanks of the Suggestions
Old Mar 23, 2003 | 04:17 AM
tom_l's Avatar
hmmm, not sure about what your autox friends are saying, but see if you can get some st sway bar brackets or make some like that.
better do it soon or you're going to tear out the chassis there.
Old Mar 23, 2003 | 08:22 AM
Snapshift's Avatar
Default Re: Snapping swaybar Brackets on my 89 SI Hatch, HELP! (tom_l)
That is why i need to create a subframe with a upper bar back there as well. Preventing the chassis from flexing as much. If i just make stronger brackets the mounting points will definately pull apart, much like the heavier & longer Integra's do when pushed to their limit. Spoon makes the bar that i need and will install pronto, My problem is now solved! Oh, by the way my buddy's are pilots for Spoon, Bride, Walker Pro and are official represenitives of their prouduct. Thanks guys for your thoughts even the dumbass one Hahahaha
Old Mar 23, 2003 | 08:42 AM
essex's Avatar
This whole thread didn't make sense if you know what to do then why ask for help?
and if your buddies are "piolts" for "Spoon, Bride, Walker Pro" then why ask for help on here?
Your chassis isn't flexing if the brackets are breaking...obviously the brackets are weak just get better brackets.
Maybe your bar is binding, if endlinks don't break then the bracket will break.
You only reinforce the chassis if the chassis breaks but thats not happening so whats the point of making a subframe.
What is a rear 22 mugen lower tie bar?
What is a highly tuned d16 have to do with your handling?
Ek-Xang
Feb 4, 2010 12:30 AM
Coolcat55
38
Jun 26, 2008 02:50 PM
televascular
Suspension & Brakes
Apr 21, 2008 03:12 PM
rallyeguy
Jul 31, 2004 10:15 AM
^Sammy]!.
Feb 9, 2004 07:39 PM
