jdm b16a swap help
Old Mar 22, 2003 | 09:37 AM
LD_EGSICK's Avatar
Default jdm b16a swap help
i'm swaping a a jdm b16a(hondamotorsonline.com) into my 91 si. for the swaping over the wireharness i had i extra plug that i can seem to find where it goes to. on my old si motor it was plug up on the IMF in the back of it. what should i do? will my motor throw and codes if i don't have the plug hooked up? i read some where that i don't need it and i could cut it off or just zip tie it up to the harness it self soo it doesn't get caught any where.
my car new heart..........
[Modified by mysiqu, 6:46 PM 3/22/2003]
Old Mar 22, 2003 | 09:47 AM
RCautoworks's Avatar
Default Re: jdm b16a swap help (mysiqu)
What did the plug look like ? It could be a plug that is just located in a different spot on a b16.
Old Mar 22, 2003 | 09:53 AM
Malgerus's Avatar
Default Re: jdm b16a swap help (90blackcrx)
I hear the 89-91 Si's have extra stuff on the backs of the IM's. My old 89 Si. I simply left it unplugged. Post a pic?
Old Mar 22, 2003 | 10:02 AM
Adam F's Avatar
if it is a 2 wire small plug(rectangle) then you are fine it does not get used
Old Mar 22, 2003 | 10:07 AM
LD_EGSICK's Avatar
Default Re: jdm b16a swap help (Proelite103)
yeah that is what it is. would my ecu throw any codes?
-i'll get some more pictures laters.
Old Mar 22, 2003 | 10:09 AM
Adam F's Avatar
no it shouldn't
Old Mar 23, 2003 | 05:41 AM
Fred n J_v2.0's Avatar
i just finished my b16a swap.. you can just tape it off or cut it off, whateva you chose, it wont throw any codes
Old Mar 23, 2003 | 09:04 AM
Rywire's Avatar
Default Re: jdm b16a swap help (95VXFRANK)
Yes, this is right. Just tape it into the harness, with electrical tape. It is unneeded on the B16a. Ryan
PS, no codes will show because of it.
ninty1civic
Nov 11, 2009 11:33 PM
user 72830283
13
Sep 18, 2005 12:20 PM
nousername
Jun 23, 2004 07:31 AM
Nameless RB26
Oct 13, 2002 10:56 PM
