Best Suspension setup for under $700 ?
Old Mar 22, 2003 | 07:55 AM
gsrhatch530's Avatar
Default Best Suspension setup for under $700 ?
I want between 1.5-2.0" drop. What is the best setup for good handling but not all out race?
Old Mar 22, 2003 | 08:06 AM
georgiajdm's Avatar
Default Re: Best Suspension setup for under $700 ? (gsrhatch530)
springs and struts... hr or eibach matched with koni, bilsteins, tokicos.
I've got eibach with stock struts and the ride is compliant...I'll end up getting bilsteins or tokicos in the future.
Old Mar 22, 2003 | 09:52 AM
1fast5gp's Avatar
Default Re: Best Suspension setup for under $700 ? (georgiajdm)
Eibach Pro Kit with Koni Yellows or Tokico Illuminas
Old Mar 22, 2003 | 11:18 AM
TimeRacer's Avatar
Really depends on what your opinion is of "best." Most of the spring sets out there are too soft if you compare them against the GC or Tein setups.
Old Mar 22, 2003 | 12:12 PM
DsITR's Avatar
Default Re: Best Suspension setup for under $700 ? (TimeRacer)
Best under $700..Ground Control coilovers w/KYB agx dampers.
if you are willing to spend more get koni yellows w/GC's or TEIN's
Old Mar 22, 2003 | 12:14 PM
Xlerate9's Avatar
Default Re: Best Suspension setup for under $700 ? (dsludefosho)
Nuespeed sports with KYB AGX. And you will have some money left over for some strut bars.
Old Mar 23, 2003 | 10:45 AM
Default Re: Best Suspension setup for under $700 ? (Xlerate9)
I already have a Neuspeed strut bar. I definately want the KYB's(I did some research). I don't like the Eibach pro kit(too rough of a ride) i'll probably get some H&R springs. I want performance but I don't want to feel every tiny bump either. I am not into autocross so I don't need a real aggresive suspension.
Old Mar 23, 2003 | 11:05 AM
sslude's Avatar
progress sport springs with koni yellows or KYB AGX's
Old Mar 23, 2003 | 03:28 PM
Quiklude's Avatar
Default Re: Best Suspension setup for under $700 ? (sslude)
best upgrade for the money? to make it handle better, or look better? Because i believe that the single best upgrade for any car is poly bushing kits, thats just my 2 cents
Old Mar 23, 2003 | 05:21 PM
TimeRacer's Avatar
Default Re: Best Suspension setup for under $700 ? (Quiklude)
Though the only problem with the bushing kits is that if the suspension in general is sloppy having siffer bushings don't help because there is a lot more play in the stock shock/spring components than there is the bushings. Plus it's pretty obvious that the guy is looking more for looks than real world handling as well.
[Modified by TimeRacer, 6:22 PM 3/23/2003]
Old Mar 24, 2003 | 10:47 AM
prelude22085's Avatar
Honestly,I would save my money and then get tein's. It is worth it in the long run.
4twenty_CRX
13
Jun 14, 2007 02:46 PM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
antballs420
Oct 8, 2005 09:18 PM
candy eg
Feb 9, 2005 06:38 PM
jDMJeRk
Sep 29, 2003 06:32 AM
