what kind of axels are these please help...
Old Mar 21, 2003 | 10:46 PM
bossman032's Avatar
Default what kind of axels are these please help...
I am doing a SIR II swap on my DX.
will the above axel work?
thanks
much
Old Mar 22, 2003 | 08:15 AM
Flexmyrex's Avatar
Default Re: what kind of axels are these please help... (bossman032)
i cant really tell what kinda axles they are. if the tranny above is the one you;ll be using try putting the axles in and see if they fit.
sir axles w intermidiate shaft and 90-93 axles w teg interm shaft will work. my friend used 94+ teg axles and they worked fine also (cable b tranny)
Old Mar 22, 2003 | 08:19 AM
spun Vtec's Avatar
Default Re: what kind of axels are these please help... (flexmyREX)
those are b series 90-91 axels remember to look at the end on them before they to in the axle that has the clean spot on the one end before the splines goes on the driver side (goes into intermedite shaft) and the other side goes on the driver's side
good luck
-larry
Old Mar 22, 2003 | 12:21 PM
unabonger's Avatar
look like B series 90-91 integra
Old Mar 22, 2003 | 12:28 PM
BTLFED's Avatar
Default Re: what kind of axels are these please help... (4gsicivichatch)
Umm....the top axle with the left side splined all the way down goes into the intermediate shaft last time I checked, not the one on the bottom that is only splined half way down. The one on the bottom should go on the passenger side.
Old Mar 22, 2003 | 01:10 PM
bossman032's Avatar
Default Re: what kind of axels are these please help... (BTLFED)
Modified by bossman032 at 8:25 AM 12/28/2003
EK_vzla
Nov 12, 2007 10:35 AM
bipedbear
Apr 4, 2006 12:33 PM
oneslodx
May 26, 2004 11:57 PM
ricodemus
Dec 4, 2002 06:28 AM
Rob!
12
Nov 14, 2002 07:14 PM
